Car seems to have a dead battery [I no it's good]
dbshubin
Hi to everyone,
I'm trying to start my car and it acts as if it has a dead battery. I know it's good, it's had a charger on it for a day or so. It's reading 12.7 volts.
Someone told me my coil is bad, but I don't think that would have anything to do with it turning over or not. It would just prevent it from starting maybe is how I see it. The starter should still turn the engine over.
Can anyone point me in the right dirrection? Is there soppose to be a ground wire coming off the starter? Becouse I can't see one. It may just ground itself. I know there's away to jump it with a screw driver. Not sure how, do you do it at the relay leading to the stater? To test if the starter is good?
Falkon
I had a problem relatively the same to yours from what it sounds like.
You should check all these things to help you figure your problem out. And just so yo know the starter is grounded to the engine/car.
First try to turn the engine by hand. That means going to the front and trying to turn the crank shaft. If it turns then you wont have to rebuild you engine like i am currently doing.
Second when you turn the key to start the car, if you hear a clicking noise or something like a tapping sound it might be your starter trying to turn the engine but not having any success. If that's the case that means either a bad starter or a ceased engine.
Now if you hear nothing i would check your solenoid and your coil. Either one of those could be causing the problem.
For your sake i hope its just something electrical. That's all i know cause that is all iv gone through with mine. Hope iv helped out in some way. :smile:
dbshubin
Re: Car seems to have a dead battery [I no it's go
Could a bad coil cause this to happen? Some one that I know looked at it and said that the coil was bad. I have sense bought one. ( I believe ) I bought one from Advanced Distributors over a week ago. I have not heard anything from them. They have yet to even send me an email saying I bought one. Although my credit card has been charged long ago. They said they custom make them to your car.
So what I'm wondering now is if that could be the missing link to the puzzle? Or if there could be more wrong with it that I may address it now while I wail for the coil.
By the way the car does turn over once or twice with the key and then nothing. No clicking no other noises either.
spritenut
Try jumper cables incase the battery has a bad cell.
12 volts is fine but how many amps? The starter needs amps.
Or the starter may be going bad.
If it turns over a little, it's not enough amps or the starter is toasted.
Bayless
If it "turns once or twice" then it really sounds like the battery although it could still be the starter. Get a jump from a known good one to know for sure. In any case, it is not the coil.
Tho i have not heard of this in quite a while- sometimes the battery posts can crack internally and give problems.
m
Sarastro
If it won't turn over, the problem is not the coil. You may or may not have a bad coil, but that's not the problem at the moment.
The only way to be really sure that the battery is good is to load test it. It can charge all the way to 12V plus and still not be good when it's loaded.
90% of these problems are bad electrical connections. 10% are the battery or starter. But, having said that, the fact that it turns over a couple times and then stops really sounds like a bad battery to me.
dbshubin
It was a dead battery. Then I should have said," I thought I was a good battery."
Thanks to everyone for your help.
David Shubin
jlaird
LOL, bet more than one of us have done that.
dbshubin
Boy oh Boy, I sure did feel like a ya ya! I guess I just had it on the charger to trickle charge and it took two days to fully charge up. I'm just glad I was buzy for the two days or I would have kept trying and never figured it out.
Thanks again
David Shubin
you guys are the greatest here I must say
Sarastro
I've found that one of the most useful tools you can have is a good battery charger. I dropped $50 for a 15-amp, "intelligent" charger that adapts to the battery's state of charge. Especially important if you have a generator; the old generator/control box system really does not do a good job of keeping the battery charged correctly. This directly affects battery life.
jlaird
Intresting you should say that Steve. Miss Agatha has a generator and is running the battery installed during her restoration, never been charged by anything but the generator.
Sarastro
The problem with the conventional generator and control box is that it charges the battery at about 13.7-13.8V, which is not high enough to avoid sulfation at the negative (I think....) plate. And, it doesn't even do that very well. The higher, constant charging voltage of the regulators in modern alternators ( about 14.5V) is one reason why battery life is a lot longer these days than 30 or 40 years ago. The battery technology hasn't changed that much, but the charging system sure has.
Back when I had a generator, I was always recharging the battery. Any time I was working on the car, if I had to start it often, it would eventually give up. Putting it on a charger once in a while at 14.5V stopped that problem. It's possible, though, that the control box was not in perfect adjustment (even though it checked out fine by the method in the manual) but in any case it was probably no worse than most of them out there.
7 My car seems to have gotten crypty's disease. Triumph 16
Rick_Thompson TR2/3/3A Sanford Fl All British Car Show, April 6th Triumph 0
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
A Why is my car making this noise? Other Cars 5
N Wanted Help with car identification Other British Classifieds 2
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
tr6nitjulius General TR British Car Mechanic SoCal Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
Hamish Racing TR2/3/3A Road trip video - car info Triumph 0
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
drooartz MGB Any risk rolling car on dry bearings MG 4
mctriumph General TR NEVER start a car with stale gas Triumph 0
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
AngliaGT Today's Car Show Spotted 8
P Where’s the British car? Spotted 4
apbos Help Identify this car chassis Racing 20
mezy some dreamers out there in classic car land Jaguar 8
B How to Get a Proof of Income for a Mortgage or car loan? Other Cars 3
Basil Alfred Hitchcock Frenzy - What car is this? Spotted 6
dougie Use your car as it was meant to be used Austin Healey 15
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
LAW75 Car Trailer Austin Healey 20
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
A General MG 2022 Car Display Geelong MG Car Club MG 2
glemon TR5/TR250 This is The Car Triumph 1
S Well, it is an RWA car Spridgets 2
AngliaGT At Today's British Car Club Meeting Spotted 7
Celtic 77 MGB Car history MG 1
Basil Internet Movie Car Database Other British Cars 0
Basil Hagerty Car Valuation Tool Other British Cars 1
L Can anyone tell me what car this is from please? Other Cars 0
shadowfever Rugby Car Show Spridgets 3
P Unknown British sports car Spotted 7
drooartz Viability of a parts/donor car Spridgets 6
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
Boink Kit Car? Spridgets 7
T Wanted PANTHER J72 or AUSTIN POLICE CAR switches Other British Classifieds 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
drooartz MGB Early tail lights on later car MG 17
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
