Bugeye on Discovery Channel
JohnDough
Don't know if you've seen it already , but Discovery Channel will be showing some wreck rescue - a lady rebuilding a frogeye. Starts 5th Feb.
I saw that when someone posted a copy online. It was two short episodes with not a lot of detail, but not a total waste of time. I'd probably watch it again if it were on TV here.
I guess it might be inspirational to some people. However, I was left with the feeling that her dad ended up doing much of the work because she had bitten off more than she could chew and that her long, hard, work was not compensating for her unrealistic schedule/budget and novice skills.
The program is Wreck Rescue, and I do not think it is on the 'merican Discovery Channel
J
JohnDough
I missed it, hope they have a rerun shortly!
racingenglishcars
I have both on my computer here at the office but together they are 584Mb and I can't get them up on my picture server.
If anyone has a way of posting them I'll be glad to put them up.
OK, I'm putting them up on megashares. They are taking about a half hour to load on the high speed connection at the office, an hour at home.
Go to https://www.megashares.com/search.php and search for "evans frogeye" one is named frog1.mpeg, the other frog2.mpeg.
racingenglishcars
Here's number one
https://d01.megashares.com/?d01=0137fa0
and number two
https://d01.megashares.com/?d01=513c2d6
The search as mentioned above finds them also.
Go towards the bottom of the page and there should be a download link.
I don't know about how much downloads they will do but they say unlimited download and it's good for 25 days.
Or try this for number one
https://www.badongo.com/vid/620005
and this for number two
https://www.badongo.com/vid/619093
I put them up on a more permanent server, the Danish Boy Scouts.
https://internetgruppen.dk/nkj/blaa/privat/
But since this is a private server (belongs to my friend), it is password protected.
User name is "privat"
PM me for the password.
J
JohnDough
Thanks, will defintely have a look at it tonight
Tullamore
If you have problems playing the movies, they are DIVX files not MPEG.
Change the extension on the files to .avi or .mp4 and then your program will not get confused looking for mpeg1 compression when it is actually mpeg4
mrsprite Bugeye on Discovery HD Theater show 'Wreck Rescue' Spridgets 3
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
