    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Bugeye horn brush help please
ichthos
Can someone tell me how long the horn brush is supposed to be? The one I got from Moss has a total length of 2 1/8". The plastic casing is 1 11/16". I measured the distance through the steering wheel and it is only 1 1/4" This wouldn't be the first time I received the wrong part. The problem this time is that I do not have an original to compare it to. The plastic case seems to start to slip in ok, but does not go all the way down. What was left of the old horn brush casing was flush with the inside of the steering wheel. Also, does the long brass hexagon shape face up toward the driver or face the dash? Any help would greatly be appreciated.
Kevin
mrsprite
I'd like to know as well. I bought a Moss replacement years ago and I can't even get it to fit in the hole <insert bad joke here>.
I think I got the wrong part too, but who knows?
Platinum
You may have been sent one for an MGB. The hex end should go in first, IIRC. It acts as a brush on the ring under it. I've MacGyver'd the things using a <span style="font-style: italic">BIC</span> pen case in past when they were NLA. It takes some fiddling to get length and diameter right with the length of the "pigtail" and spring on whatever you use as a brush, but being inventive can yield a working bit.
jmwuva05
I have cut the brass end that touchs the horn push down with a haksaw then filed it smooth to the correct length and it works perfect. The main problem I have is keeping the wheel from grounding to the steering shaft. Made a thin plastic shield to isolate everything.
Whitephrog
Total length tip to tip is 2 7/8". Plastic sheathing is 2". Movable brass piece is 3/4" exposed. Brass tip is 1/8".
Long brass piece goes up.
I
ichthos
If I could see a picture and measuements I think I could alter my horn brush, but I have no idea how it fits into the steering wheel. For instance, how long it the plastic part? Is it just the length of the hole through the steering wheel, 1 1/4"? Isn't the circut for the horn completed when the driver pushes the horn push and it touches the center steering shaft/nut? If so, would I just need to make sure the longer brass hex piece was able to touch the horn push, and yet be short enough so that when I push down it allows the horn push to make contact with the shaft/nut?
Kevin
I
ichthos
Looks like we were writing at the same time, Ray. The plastic piece on mine is only 1 11/16", which is shorter than what you have but still seems too long to me. The longer brass piece sticks out 9/16". The short piece sticks out 1/8". The longer shaft depresses 9/16". Can you remember if the plastic part is flush with the inside of the steering wheel? Remnants of the old brush were still in the steering wheel when I took it apart. The plastic sleeve had a lip on it that made it flush with the inside of the steering wheel and stopped it from moving toward the steering wheel surround (the new one does not have this). I am probably making a bigger deal out of this than I should, but I have been sorry before when I have jumped in and tried to alter a piece before I knew what I was doing.
Kevin
Whitephrog
The top of the plastic is flush with the outer edge of the wheel.
M Some Tech Advice Needed for Horn Brush on 59 Bugeye Spridgets 10
I Horn brush installment help for Bugeye please Spridgets 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
P Grounding of Horn Push-Bugeye Spridgets 4
J WTB: NOS bugeye horn button, and MkII Sprite Hood Emblem Spridgets 1
I Correct horn for a 59 bugeye? Spridgets 19
I Bugeye horn repair help Spridgets 7
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
