Bugeye bonnet gaskets - do I really need these?
ichthos
Hello,
I think there are gaskets between the hinge and bonnet. Is this correct, and if so, are these really needed?
Kevin
Jim_Gruber
Yes in order to keep the curve in the bonnet across the top, source from McGregors in CA. Ones from usual suspects don't fit.
I
ichthos
Are we talking about the same thing? I am referring to the gasket that goes in between the four bolts on each hinge and the bonnet.
Kevin
spritenut
The original hinge gaskets were 30 wt tar paper.
If you see any roofers in your area, ask them for a scrap of 30 wt tar paper.
This is what was used for the pedal box too.
Whitephrog
Kevin
Frank is correct. The original was tar paper. I made mine from 2mm dense cell foam from a craft store. I has concerned about the foam absorbing moisture. I soaked a piece in water for several days with zero absorption. This foam is very similar to the replacement gaskets commercially available for the pedal box and blanking plate.
I
ichthos
Thanks. I am pretty sure I already have tar paper in my attic somewhere. I am still curious as to what the purpose of the gaskets are. Do these function in helping the bonnet keep its curve, as Jim stated, or was he talking about the rubber strip that goes in the channel that the bonnet rests on?
Kevin
Jim_Gruber
I was talking about the rubber strip at the back of the bonnet that supports it against the channel. The one from McGregor fit well while the one from MOSS and VB need to be stretched to make fit and are very challenging to install.
I
ichthos
I can't remember if I bought my rubber seal from Moss or VB, but it does not fit well. I need to order new seals for my factory hardtop, so I will try one of MacGregor's rubber strips and see if it makes a difference. Thanks, Jim
Brian_James
The word is that if MacGregor sells it, it fits. I have his bonnet seal and door seals on my bugeye, and I am very happy with the fit and quality. He works best over the phone. Just give him a call.
Brian
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Rhodyspit75 Bugeye bonnet brace. Spridgets 5
M Bugeye Tilting Bonnet Hardware Spridgets 2
Gerard Bugeye bonnet and entire rear clip Spridgets 4
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
Rut Bugeye bonnet insulation Spridgets 4
Rut Bugeye bonnet handle escutcheon Spridgets 9
Rut Bugeye bonnet mirror Spridgets 11
Rut Bugeye bonnet fit Spridgets 19
Rut Bugeye bonnet gas struts Spridgets 6
Editor_Reid Securing Bugeye Fiberglass Bonnet Spridgets 15
TulsaFred Bugeye bonnet prop rod Spridgets 7
6 crossflow radiator with bugeye bonnet? Spridgets 5
Rut Bugeye bonnet Spridgets 0
DanLewis New fiberglass Bugeye bonnet $395 [NFI] Spridgets 0
Rut Bugeye bonnet Spridgets 1
Rut Bugeye bonnet Spridgets 5
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
I Anyone have a bugeye bonnet hinge or bonnet stay they could sell me? Spridgets 5
bugedd Bugeye bonnet differences Spridgets 9
I Help removing bugeye bonnet please Spridgets 5
P Bugeye Bonnet Latches Spridgets 7
Hairyone bugeye bonnet radiator cowl Spridgets 3
I bugeye bonnet welding help please Spridgets 11
Rut Bugeye bonnet latch Spridgets 13
RickB Bugeye Bonnet $100 on Santa Barbara craigslist-nfi Spridgets 1
The_architect Bugeye bonnet badges Spridgets 7
M Bugeye bonnet sheetmetal question Spridgets 12
I Tips or installing Bugeye bonnet needed Spridgets 14
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
I bugeye bonnet wiring harness fasterner help Spridgets 16
R bugeye bonnet Spridgets 7
P Bugeye bonnet on Craig's list Seattle Spridgets 6
RickB Bugeye Sprite Bonnet found on Ebay only $2900!!! Spridgets 11
M Tilt Bonnet Hinge Kit 4 BugEye Spridgets 8
Morris Winner's circle Bugeye Bonnet Spridgets 4
M Bugeye bonnet mounted on later sprite or midget? Spridgets 21
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
Jim_Gruber Bonnet Seal / Bugeye Bonnet on Mark IV Sprite Spridgets 5
Branson Free bugeye bonnet <-- well almost Spridgets 1
drooartz How many guys to pull a Bugeye bonnet Spridgets 19
Jim_Gruber Getting the curve back in a Bugeye Bonnet Spridgets 3
Jim_Gruber Bugeye Bonnet Installation Up-date Spridgets 3
Jim_Gruber Trimming Inner Fender for Bugeye Bonnet Spridgets 13
racingenglishcars Jyllandringen grand prix Bugeye bonnet Racing 6
Morris Bugeye Bonnet SWA Butt Spridgets 0
John Moore Bugeye Bonnet Question Spridgets 6
