BT7 head manifold studs
  • Thread starter Deleted member 21878
  • Start date
i purchased three different manifold studs for the head. went out today just to see where they should all go. the parts pictures i have are not very clear. basically you get 5 short intake studs. 2 long intake studs and 6 exhaust studs. the 2 long intake studs and the exhaust studs look just alike to me, so really i got 8 long studs and 5 short ones.
in the pic below you can see how i placed them in the head. the three center ones at the bottom and the 2 center ones at the top are the 5 short ones. is this where they should go? i do not want to put longer studs in where they might hit the throttle linkage or something else.
Thanks
Keith_M
TL,
Here are a few pictures that may help.
Keith
Keith
Thanks for the pics. i tried to blow them up. it looks like you have seven short studs and six longer ones. not what Moss shows but maybe i have something mixed up in the way i read it. might order two more short ones just in case.....
steveg
From the Moss catalog, there are 17 studs total.
Guessing about the disposition:
7 for the intake manifold-only, except for the common ones with exhaust on either end. The exhausts would be the 10 long ones to accommodate the tall nuts.
Guessing the exhausts would have more stress due to the weight of the manifolds etc and would therefore be the longer ones.
steve
actually i believe four of those are bolts, that run thru the exhaust manifold and are not studs.
what i question are the intake studs. they call for 5 short ones (#724-075) and two longer ones (#724-080). i am just not sure where they want the longer ones to go. a number of my studs were missing when i bought the car so i can not go back to old pictures.
After looking at some pictures i took at a car show of a tri-carb, it looks like all the linkage is outsite the heatshield, which makes sense. so there is nothing behind the heatshield that these bolts should hit. I can probably put them either place.
Maybe i will send a note to the Moss tech department and see what they say.
red57
One correction - there are no bolts, they are all studs, course threads in head and fine threads for nuts. The long studs are for the exhaust with brass nuts & the short are intakes. It's been a while but I think the 2 longer of the short ones are for where the heater tube supports are but I don't really think it matters much where the various 'short' ones go.
Dave
Dave
on my exhaust manifold there are 4 bolts that run in to the bottom four holes in the head. you can see those hole in Keith's picture. the bolts are number 25 on the Moss page. they do not show available. but that is what i was talking about. sorry if that was confusing.
red57
Drone Dog... I forgot you have a tri-carb and yes, in your case there are bolts. I run 3 HD6 myself but with headers so no long bolts in mine & I forgot what the stock set-up was like. sorry for any confusion I caused.
Dave
D bt7 head surprise Austin Healey 7
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
