Brake Master Paint Color
Scot
Anyone know what the correct paint color is for the after market cast iron brake master cylinder?
I'm not sure if it's black or an aluminum silver.
I'm in the process of rebuilding mine on the BJ8.
John Loftus
The master cylinders for the 100 were cast iron and painted black but the 6 cylinder cars with separate brake and clutch master cylinders are unfinished cast aluminum. Since the BJ8 master cylinders currently supplied are cast iron what ever you paint it will not be correct. Aluminum paint color will look more like aluminum but if you really want to be correct in finish then you should find a used aluminum master cylinder and have it resleeved. Hope that helps a bit!
Cheers,
John
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
D BJ8 brake master cylinder question Austin Healey 6
D TR2/3/3A Brake Master Cylinder. Triumph 4
Michael Oritt Brake Master Cylinder access Austin Healey 0
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
R brake master missing seal Austin Healey 11
vickxxx T-Series Brake master adaptor MG 2
M TR6 Brake master cylinder question. Triumph 2
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
T TR2/3/3A another brake master cylinder question Triumph 16
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
D MGA Master Brake Cylinder Leak MG 2
nevets question about brake master cylinder Austin Healey 12
Lukens More clutch / brake master cylinder questions. Triumph 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
Jim_Gruber Brake Master from Alternative Sources Spridgets 10
KVH Bleeding the Brake Master Cylinder Triumph 8
J TR6 TR-6 Brake Master Cylinder Seepage Triumph 4
J TR6 TR-6 Brake Master Cylinder-Rebuild or Replace ? Triumph 4
D Brake master cylinder Austin Healey 1
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
A Wedge 1980 TR7 Brake master Question Triumph 5
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
rlich8 TR4/4A TR4A Brake Master Connector Leak Triumph 2
A Divided brake master cylinder MG 6
1 Brake Master Cylinder Spridgets 11
K TR4/4A TR4A Master Brake Cyl Internal Spring Clip? Triumph 6
K TR4/4A TR4A Brake Master Cylinder Internal Spring and Triumph 13
E BE w/dual line brake master....90 degree fitting? Spridgets 12
E 1275 Brake Master Nylon Bushing Spridgets 3
letemglow Brake line layout with dual master cylinder MG 6
