TR2/3/3A Brake Master Cylinder.
DavidApp
I seem to remember reading a thread a while ago about someone having problems getting good brake peddle action. Having to bleed repeatedly etc.
Watched a comical You tube video of a guy bleeding his brakes by pumping like crazy.
My TR3A kit came with 2 brand new in the box Girling MCs. Still sealed in the plastic sleeve and had the plastic plugs in the ports.
I piped up the car and filled it with DOT5 fluid. The clutch worked and still works with no problem but the brake MC seemed slow to return the peddle. Having bleed the brakes several times I would get a good hard brake peddle with a little travel but a second push there would be nothing for about 1/4 of the travel unless you waited a few seconds. It was then like it was for the first push. The MC piston was not returning immediately. Did a couple of short drives down our road and decided I needed a new MC. rakes worked fine but it was scary with that short section of nothing before they acted. It was this way stationary so it was not warped discs.
Fitted the new MC and that fixed the problem.
With the old one I can push the piston back by hand and it takes several seconds to return to it's fully out position. Going to take it apart to see what is wrong.
Could this be the cause of some of the bleeding issues people were having?
David
Graham H
David, you may find the piston cup has been turned over on itself I had that with a new slave cylinder but I also had a new Girling MC that just would not behave a bit like yours I finished up getting my original reconditioned and haven't had any problems since
Graham
TomMull
I had similar issue with the clutch and polishing the bore fixed it. Mine was rebuilt and honed however, so should not happen with a new one. Also, dot5 seems to be less slippery the earlier brake fluids. I will be interested in what you find.
Tom
DavidApp
Took it apart and the bore looks fine and the seals looked OK. The grease on the outer seal was a but stiff but it was 20+ years old. On reassembly it is still a little slow but almost normal. I think some fresh Girling grease would fix it completely.
The new one is working great and I do not plan to swap them out again.
David
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
D BJ8 brake master cylinder question Austin Healey 6
Michael Oritt Brake Master Cylinder access Austin Healey 0
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
M TR6 Brake master cylinder question. Triumph 2
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
T TR2/3/3A another brake master cylinder question Triumph 16
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
D MGA Master Brake Cylinder Leak MG 2
nevets question about brake master cylinder Austin Healey 12
Lukens More clutch / brake master cylinder questions. Triumph 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
KVH Bleeding the Brake Master Cylinder Triumph 8
J TR6 TR-6 Brake Master Cylinder Seepage Triumph 4
J TR6 TR-6 Brake Master Cylinder-Rebuild or Replace ? Triumph 4
D Brake master cylinder Austin Healey 1
A Divided brake master cylinder MG 6
1 Brake Master Cylinder Spridgets 11
K TR4/4A TR4A Brake Master Cylinder Internal Spring and Triumph 13
letemglow Brake line layout with dual master cylinder MG 6
Gliderman8 Brake Master Cylinder info Triumph 1
doughairfield Brake Master Cylinder leaking Triumph 11
J TR4/4A TR4 Master Brake Cylinder Rebuild Triumph 3
letemglow Adjustable rod on brake master cylinder Austin Healey 3
S BRAKE LINE MASTER CYLINDER Triumph 1
doughairfield Master Brake Cylinder Rebuild ? Triumph 18
T MGA What color should an MGA brake master cylinder be? MG 6
letemglow Brake master cylinder BJ8 Austin Healey 0
dklawson Spitfire Brake Master Cylinder Quality - Spitfire MkIV Triumph 2
Camshaft Brake Master Cylinder Rebuild Spridgets 11
D Wedge Power Brake Booster/Master Cylinder for TR7 Triumph 4
E Is this Brake Master Cylinder Salvageable? Triumph 23
Q TR2/3/3A TR3 Brake Master cylinder rebuild Triumph 5
VelodromeRacer Brake master cylinder upgrade? Racing 4
B Brake Master Cylinder R&R MG 12
