Brake Master Cylinder R&R
Bruce74B
I finally broke down and bought a new master cylinder for my 74 B. It has been years since I did this job, so I got out the Bently and read that they say to drain and remove the CLUTCH master cylinder, too and then remove both MCs along with the pedals. This makes sense, if everything was pristine on a 35 YO car, but I am not thrilled about messing with the clutch slave and bleeder. SO, my question is "is it necessary?" Is it possible to leave the clutch MC in place and slide the brake master cylinder and mounting bracket out over the end of the clutch MC? Any and all suggestions would be appreciated.
Bruce
Scott_Hower
Yes it is possible, no you do not need to remove the clutch MC.
Having the hands of a 10 year old will help :smile:
Getting the pedal box cover off is usually the biggest challenge. I think I drilled 3 screws out as all were stripped...
B
Bruce74B
Well, I have the cover off...took it off and repainted it a couple of years ago. I am just to the point of taking the pedal off and it looks like I can slide it out of there with the clutch MC intact...if I can get the little bits out of the way, but I can take my time and do it that way, even if it takes longer and not have to mess with bleeding the clutch, etc. I will try it once I get the AC operating again...the heat has priority over my LBC ;-( Thanks
Bruce
Platinum
1/4" drive swivel socket!! :laugh:
B
Bruce74B
I only have a 3/8" knuckle, but I think it will fit down there. And I have to get it done this weekend and move her, so that we can get the new furnace in past there...uggg! I am just hoping I can pull the mount out past the end of the Clutch MC and over the briake lines and gas line in front of it. Thanks for the encouragement...it will help steel my will.
Bruce
Scott_Hower
You can also pop the 4inch rubber plug out of the back of the firewall to gain you a couple more inches of wiggle room.
Rereading this again ... are you trying to unbolt/remove the brake MC from the pedalbox itself (leaving the box bolted in situ)?
Or are you trying to unbolt the clutch MC from the pedalbox and remove the whole enchilada with the brake MC still attached?
The former is possible, but a hassle. Never tried the latter. If it were me, I'd just bite the bullet and bleed the clutch; if you have not changed the fluid and the clutch hose in a while, it's a good opportunity to do it.
B
Bruce74B
I am considering the latter...pulling the Brake MC and mount with the Clutch MC still in place, but I am beginning to think that bleeding the clutch might not be so bad after all. I need to get under there and see why the speedometer stopped working anyhow. I was looking for an easy way to get it done, but looks like I need to take the bull by the horns and do it this weekend. Thanks.
Bruce
Scott_Hower
Bruce-
Note the alignment of the banjo fitting on the rear bore of the MC before you remove it. Trying to tighten that thing down once fitted is next to impossible.
Also, replace the copper crush washers for good measure. I think there is one either side of the banjo ... MC/washer/banjo/washer/bolt. Same deal with the forward fitting, only there's only one.
B
Bruce74B
Thanks...it is in place but not fastened down yet, so I can align it next. The new MC came with new copper washers, so I did that, too :thumbsup: I just need to get my nighbor to bring over his two year old son to put the bolts back into the support and tighen them up. It wasn't as bad as I remember it, though.
Thanks again for the help...maybe I will get her out for a spin today, before it storms :driving:
Bruce
Scott_Hower
Great news Bruce!
I usually tape the socket onto my 1/4in extension REALLY WELL, then tape the bolt lightly onto the end of the socket. Works great.
Glad to hear it's getting there.
Platinum
Butyl windshield "tape" works well for holding fasteners to tools, too.
B
Bruce74B
I did use the tape for the inside bolts to the firewall with my cordless rachet, but where I can use both hands, I got out my trusty copper wire (14 gauge single strand works best) and looped the bolt through it, put the wrench on it and lowered it into place. Once it is started, as slight tug on the wire unbends the wire and it puts out :thumbsup:
She is back on the road again :driving:
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
D BJ8 brake master cylinder question Austin Healey 6
D TR2/3/3A Brake Master Cylinder. Triumph 4
Michael Oritt Brake Master Cylinder access Austin Healey 0
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
M TR6 Brake master cylinder question. Triumph 2
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
T TR2/3/3A another brake master cylinder question Triumph 16
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
D MGA Master Brake Cylinder Leak MG 2
nevets question about brake master cylinder Austin Healey 12
Lukens More clutch / brake master cylinder questions. Triumph 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
KVH Bleeding the Brake Master Cylinder Triumph 8
J TR6 TR-6 Brake Master Cylinder Seepage Triumph 4
J TR6 TR-6 Brake Master Cylinder-Rebuild or Replace ? Triumph 4
D Brake master cylinder Austin Healey 1
A Divided brake master cylinder MG 6
1 Brake Master Cylinder Spridgets 11
K TR4/4A TR4A Brake Master Cylinder Internal Spring and Triumph 13
letemglow Brake line layout with dual master cylinder MG 6
Gliderman8 Brake Master Cylinder info Triumph 1
doughairfield Brake Master Cylinder leaking Triumph 11
J TR4/4A TR4 Master Brake Cylinder Rebuild Triumph 3
letemglow Adjustable rod on brake master cylinder Austin Healey 3
S BRAKE LINE MASTER CYLINDER Triumph 1
doughairfield Master Brake Cylinder Rebuild ? Triumph 18
T MGA What color should an MGA brake master cylinder be? MG 6
letemglow Brake master cylinder BJ8 Austin Healey 0
dklawson Spitfire Brake Master Cylinder Quality - Spitfire MkIV Triumph 2
Camshaft Brake Master Cylinder Rebuild Spridgets 11
D Wedge Power Brake Booster/Master Cylinder for TR7 Triumph 4
E Is this Brake Master Cylinder Salvageable? Triumph 23
Q TR2/3/3A TR3 Brake Master cylinder rebuild Triumph 5
VelodromeRacer Brake master cylinder upgrade? Racing 4
