BN1 Engine Mount rubber parts
RCarr
Hello all. I'm working to get my engine back into (what will soon be) a rolling chassis. It's an early BN1 and the rubber parts available at Moss are disappointing. From what I see in other posts I already don't expect them to last very long, but the fit and function are my current concern. The small rubber part, called "Buffer" is smaller than the original part in width and thickness. I will have to build a 1/8" shim to put it close to where the original part was. Shims were used originally, but for only for adjustments of less than .050", not .125". So the question is, what is the correct distance between the buffer and the lower metal part of the mount. You can easily see the difference between the original part and the Moss part in the photo. I don't expect to find a supplier of early BN1 rubber parts so I want to manufacture the right size shim in order to get this engine mount to perform properly without tearing the larger rubber part (which I also had to modify to fit :apologetic:. Thanks for any insight into this engine mount and how critical the clearances are between the buffer and the lower mount bracket.
Just had the same problem when installing my rebuilt BJ8 engine--AFAIK, all Big Healeys use the same mounts--and again when I installed my BN2's engine a few years ago (yeah, the new mounts from Moss are junk). The problem, as I see it, is that the large gap between the top 'buffer' and the main mount allows the main mount to sag, and this can cause it to tear away from its metal backplate, causing the mount to all but fail prematurely. I used a stack of fender washers with slots cut in them--2 on one side, 3 on the other--to offset the buffers closer to the main mounts, and I hope this helps. Since you haven't installed your engine yet, you might call some other suppliers and see if they have better mounts (and let Moss know they have a bad product).
RCarr
RCarr
Thanks Bob. I was also afraid of the main mount failing because of the gap. I'll devise a shim as you did and work out a 1/16" clearance. That's what the originals seemed to have. I already talked to a Moss rep over the phone but I'll probably follow up with email and photos. I added photos of the mounts before I tore them down for anyone out there who is interested in seeing the difference between the original configuration and the Moss mounts. Again, based on other comments, I don't think there's multiple manufacturers of these mounts and buffers so we're stuck with shimming them or modifying to fit.
RCarr
RCarr
Your original mounts don't look too bad, aside from some surface cracking. I'd be tempted to re-use them.
Yeah, I kicked that idea around with a couple friends before buying the new parts, maybe now I'll lean back toward using the old buffers, they're still pretty soft except around the edges. One of the old mounts is as hard as a rock, the other I can still stick a fingernail into so I'll probably go with the new parts for those. Again, thanks for providing your own personal experience and opinion.
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
R BN1 & BN2 Engine # Plate Finish Austin Healey 25
R BN1 engine paint Austin Healey 7
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
55modified Nardi hub for a BN1? Austin Healey 10
L BN1 Transmission rebuild Austin Healey 1
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
