BJ-8 Generator Smoke
fwtexasbj8
All, think I have fried my rebuilt generator something bad! The original issue I was seeing was a fluctuation on my volt meter from an overcharge to an undercharge condition. I swapped regulators and saw the same behavior so took my generator and regulator to a local generator shop that has consistently done good work for me and others.
Diagnosis was a bad regulator so I got a new Moss unit. Once a good regulator was available, they discovered the generator was also bad so it was completely rebuilt and bench run/adjusted with the new regulator. I re-installed everything and all was good with a fairly constant 13+ volt output on the gauge during a quick 15 minute drive. I got home, shut everything off and started to get everything ready to wash her then began to smell a strong electrical smell. I opened the bonnet and smoke was pouring from both ends of my rebuilt generator! I quickly disconnected the leads and began to try to measure any unusual voltages to the field or output and with the key off, no voltage was measured. With the key on, I saw 2.3 volts on both the field and output wires. I started her to get back to my garage and only saw battery voltage so no generator output.
Any ideas what could cause this type of failure? All of the other wiring seems fine with no ground or short issues found.
pkmh
Definitely sounds like a short and at this point there are so many variables to determine the cause of your short. Sounds to me like wires or connections got crossed somehow and maybe water became a culprit based on what your are saying. Anything is possible from my standpoint from the battery onward (or generator backwards?). Electrical know how has never been my favorite so hopefully many others will get into this and help you out. Good luck.
PTBJ
This may help.......
:encouragement:
Patrick67BJ8
Did you flash the field when you hooked everything back up before starting the engine?
F
fwtexasbj8
I did not flash the field as I assumed, maybe a bad assumption, that the generator shop had as the new regulator/generator combo had been set on his bench.
Healey Nut
:encouragement:
You need the special order now obsolete smoke installation pump to be able to use this . I have one in my garage that I rent out for 999.99$ a day .
Deleted member 8987
Now, this is more generic than specific, but if it ran fine, charged fine...and the issue happened when you got home and shut down, noticed as you were getting out of the car....bets are your ammeter was pegged to discharge..the Cutout Relay (in the regulator) stuck or defective.
Supposed to open when you shut down.
Don't think flashing for polarity would cause that...and that's 50 years of 6V positive ground generator system experience.
Pop the top off the regulator, see if any contacts are stuck together.
With the main wire off the generator, you should be able to power up and test.
F
fwtexasbj8
The final diagnosis was a bad voltage regulator. Even though it was brand new, one of the coils had a pit in the contact and stuck closed which fed battery voltage back into the field essentially making it a heater. The generator was not fried, however it was over heated and the armature and brushes scorched a little. Polished the scorches and with a new regulator, all seems well again and she is back on the road.
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
M AH 100-6 Generator- SMOKE! Austin Healey 7
MGTF1250Dave T-Series Lucas Generator MG 1
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
T Spitfire MK2 Generator Triumph 3
W Generator and Starter Long Bolts Spridgets 0
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
B Generator Parts Austin Healey 6
P BN4 Generator Woes Austin Healey 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
TR3MT TR2/3/3A Generator Output Triumph 18
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
AUSMHLY Generator to Alternator Swap Austin Healey 20
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
O Generator Question Austin Healey 2
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K What to do for coil bracket on upgraded generator? Austin Healey 8
R TR2/3/3A generator to alternator Triumph 5
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
T New Generator Mystery Austin Healey 5
I Bugeye generator/alternator conversion question Spridgets 7
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
R TR2/3/3A TR-2,3 Generator Pic showing all attachments Triumph 5
doc50 Mash Metropolitan Generator testing Other British Cars 1
S TR2/3/3A generator red light deal Triumph 6
J advice on a 3 brush generator please C45N-3 Other British Cars 0
5 Tach Drive Generator for a Bugeye Spridgets 2
M Jaguar XK Special Equipment Generator Jaguar 1
T C42 BJ8 generator long screw needed Austin Healey 2
Magyar Generator going on the fritz Spridgets 3
Rhodyspit75 Generator pulley diameter Spridgets 2
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
Rut Bugeye generator color Spridgets 22
CJD TR2/3/3A Generator and other Odds Triumph 6
G TR4/4A New Generator vs Alternator vs BPNW Alternator/Generator Triumph 13
R TR6 Generator to alternator conversion Triumph 6
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
K TR4/4A Generator bench testing..... Triumph 6
G Generator - Key Replacement Austin Healey 6
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
