armchair gearbox inspection
jvandyke
Got a supposedly good rib case box for $175.
Looks okay to me.
See for yourself?
Gearbox
jlaird
Please fix your loc to something more definitive than United States, state, and or city would be nice.
jvandyke
jvandyke
Done
bugimike
That gearbox sounds fine!! I heard no nasty rattles, bearing or otherwise, etc. and the shifting seemed smooth! :thumbsup:
Platinum
umm...
what's this "Quicktime" I'm told I ~need~?!?! :devilgrin:
jlaird
Oh, another MI kind of guy. My sister lives up there as well as lots of other folks here on the form and I spent four years in Battlecreek.
Platinum
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
V TR2/3/3A I have a doubt about the gearbox Triumph 10
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
R Gearbox and Overdrive Oil Level Austin Healey 18
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
J Gearbox front cover seal Spridgets 2
