Aluminized heat barrier cloth
AUSMHLY
Should I be concerned about putting an aluminized heat barrier cloth under the heat sheild?
Here is a link to this product:
https://www.pegasusautoracing.com/ProductSelection.asp?Product=1828
Reason for asking? Keoke, you mentioned about not using a metal nut as a spacer for the heat sheild. (By the way, I got some Hardibacker from Home Depot today to use).
My thinking is that you can never have too much help tring to keep the area cool. What heat gets by the sheild, should be refected away by the heat sheild cloth?
What's your take on that? Thank you, Roger
Keoke
ASMH2, I do not use that particular product their #1832 seems a better choice.The Idea here is to put as much heat lossy material between you and the heat source as is practicle. Look in the archives a number of products have been identified in the past.---Keoke
Keoke
/ubbthreads/images/graemlins/savewave.gif
Hi ED, Welcome to the forum. How did this product perform in your car.?---Keoke
Ed_K
Hi Keoke, I don't know how much it helps yet as I don't have it all the way back together yet. I haven't driven this car since 1971 but I can remember it being hotter than h... in the summer. I am convinced that anything that I can do to insulate from the heat will be worth the time and money. I will let you know how it works once I get it back on the road.
Keoke
HI Patton, having the shinny side facing the heat source will provide the best reflective,Radiated, heat loss which reduces the materials requirement to provide conducted heat loss.some of the materials have shinny surfaces on both sides.--Fwiw---Keoke
GregW
Platinum
Hey Keoke- I tried to do that with the Dynamat Extreme, but every time I tried to push it down, it just stuck to my hands. /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/jester.gif
Keoke
Well Greg, I guess you should have cleaned your hands before you tried to install the Dynamat. He probably didn't read the instructions---Keoke-- /ubbthreads/images/graemlins/laugh.gif
Ed_K
Patton, Before I bought the thermo tec product, I read some info on one of the many sites that sells the stuff, or perhaps it was on the manufacture's site, I can't remeber. Anyway, they say the product was most efective blocking radiant heat when the aluminum side, ( oposite from self stick side ) , was pointed at the heat source. They also say if you have to mount it on the oposite side of the firewall from the motor then the aluminum side should face
away. It apparently works better in reflecting radiant heat as oposed to being used as an insolator. In any event, if you get the self stick kind, the decision is made for you. Keoke is right, it really depends on the product that you are using. I bought a insulating matt from the same place to go inbetween the floor and the carpet. The real shiny side went down towards the floor, the less shiny side , ( aluminized ? ), went up towards the carpet.
HealeyPassion Reducing Muffler Heat Austin Healey 2
steveg Heat Shields Austin Healey 17
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
V heat shield Triumph Classifieds 7
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
M Heat-related carb issue on BN1 Austin Healey 7
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
wangdango Keeping the heat out? Austin Healey 11
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
NutmegCT heat valve control cable Other Cars 0
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
69mgbgt No cabin heat in my 1997 jaguar xj-6 Jaguar 1
I Spitfire If you can't stand the heat.... Triumph 7
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
T General TR heat proofing floor boards Triumph 10
R Heat shields and other hot topics Austin Healey 36
tahoe healey Dynamat heat shield Austin Healey 8
R securing heat shields Austin Healey 11
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
NutmegCT heat barrier Restoration & Tools 3
NutmegCT TR2/3/3A TR3 cockpit - summer heat! Triumph 12
M Supercharge Heat Sheild Question [pics] Triumph 3
Russ Austin Heat ah at least warmth. Triumph 11
R TR4/4A Tr4a, alternator heat shield Triumph 9
E Asbestos heat shielding. Austin Healey 8
R Need more heat - which thermostat MG 15
J T-Series electrical heat and smoke from the switch MG 4
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
I How do I install Bugeye heat shield? Spridgets 4
Gliderman8 Heat Shield - will it solve my problem.... Triumph 15
