I separated the master cylinder from the booster so I could repaint it and the lower part of the firewall. Upon separation I could see a little wetness between the two. What was really odd, to me, was that there was some brake fluid in the booster. I removed the vacuumn connection and drained out about a 1/4 cup of brake fluid. Obviously I'll have to rebuild the master cylinder. I don't know if it's an original master cylinder or after market. I was curious if the rebuild kits sold by most vendors will work since I think the original master cylinders and the aftermarkets may not share the same kit. Any help is appreciated in identifying which one I have. I'm also curious if the booster is ok if I just drain it, possibly flush it and dry it and attempt to put it back in service. Being brake fluid I don't think it would adversly affect the booster but I'm not an expert. Any help here is also appreciated.
Art
Art
