TR2/3/3A 4-2-1 headers [or Tri-Y]
Bremer
One of the next items on my upgrade list for my 59 TR3 is an exhaust header (or extractor manifold, as they say across the pond). Reading about the differences in engine characteristics between 4-1 and 4-2-1, I think I prefer the latter because of higher torque in the low to mid range. However, I am having difficulty finding one at an acceptable price.
The only places I was able to confirm to carry this are Moss (expensive in mild steel and stainless steel) and Racetorations (mild steel only, even more expensive).
If you were in the market for one, where would you look?
Thanks!
Bremer
Bremer
Anyone?
I guess I could build my own tri-y headers, but I am missing some design details such as diameter and lengths of the primary tubes. Any input would be appreciated.
Thanks!
Monkeywrench
Bremer,
A tri-y will absolutely be better, the problem is, there isn't anyone with what you want off the shelf. A custom tri-y is going to be a lot different than what you can get.
For a custom set, you want to use as large of bend radius as you can. This means 4" for smaller diameters and as you get to 1.625od tubes, you want to start using 6" bend radius. It's all about velocity management. The other thing is to make the transition from the head to the primary as smooth as possible. Match the shape at the port and have zero step. Also make sure the tube and the port exit at the same angle (not an issue with the TRs). Designed carefully, you'll make more peak power than any of the 4-1 headers and be WAY up on the low and mid range.
A race header for a wet liner TR engine would be somewhere around: 1.5 @ 12" > 1.625" 6" or so -first collector junction - 1 7/8" for about 30" or so before a choke merge collector and into the tailpipe. A street car / lower performance car would probably go down one size on all those numbers. Best to consult with Burns Stainless on exactly what you want. It'll cost you about $75 for them to run your numbers. There are cheaper places to get the tubing you need with that bend radius. Mordy Dunst should be able to make you a header flange as well.
Cheers,
Bremer
Bremer
Bob,
Thanks for your reply, much appreciated.
I had indeed wondered where I could get a header flange from, and had forgotten about Mordy.
Also thanks for your tip to contact Burns Stainless, their website looks they have everything one might need for a custom header.
Can I ask you to clarify your statement about the diameters. I'm not sure what you mean by 1.5 @ 12" > 1.625" 6". Are you saying that the tubes from the header flange to the first Y should be either 1.5 or 1.625'' in diameter? What's the significance of the 12 and 6''?
I understand that between the first set of Ys and the last one the two tubes should be 1.875'' and 30'' long.
Thanks!!!
Monkeywrench
Yep! Those are just ballpark figures, Burns will tell you more. You want to match the port area (remember, calculate area of 1.5" which is 1.58" area (.040 wall tubing). A stock port is probably a bit smaller.. may want a 1 3/8" primary off the port. Make it square and let it transition to round, start at the top, then the sides, then the bottom.
Those first numbers are the primary. So step up at 12". You need the large bend radii to make those diameters work. The larger the bend, the more it can flow for a given diameter.
You want it as swoopy as possible like this, which is near impossible on a TR. Just try your best:
Bremer
Bremer
Ok, thanks Bob.
3 Exhaust Manifold/Headers BN2 Austin Healey 16
steveg Headers to buy - DW or AHspares? Austin Healey 5
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
R General Tech Kirk Racing headers opinion Triumph 3
R TR4/4A Were the exhaust headers painted on the TR4's Triumph 6
D Headers for BN4 Austin Healey 2
Morris Good Deal on Cheap Headers Spridgets 6
T TR6 TR6 [?] headers - actually any good? Triumph 7
bighealeysource Derrington style exhaust headers on 100-4's Austin Healey 4
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
racer_x Wedge TR8 Group buy- Kirk headers Triumph 5
racer_x Wedge TR8 Headers: Rimmers versus Woody/TSI Triumph 34
JPSmit Patriot Headers Spridgets 1
Aggudabbu LCB/ Headers clearance issues? Spridgets 4
LuckyLuke Who makes exhaust headers for AH 3000 BN7 Austin Healey 7
W TR6 TR6 aftermarket headers Triumph 26
hymodyne GT6 GT6 headers Triumph 14
KVH TR4/4A Tubular Headers/Pertronix for TR4 Triumph 12
NardisCNC Who makes the best headers?? Spridgets 9
drooartz How the *bleep* do you fit the headers? Spridgets 11
RSMTR8 Wedge TR8 Headers Triumph 13
GBRandy Wedge Headers on a FI TR8 Anyone do it? Triumph 9
5 Headers for BN4/early 3000 Austin Healey 10
drooartz Jet-Hot headers came today! Spridgets 5
boeingpilot GT6 GT6 Headers Triumph 3
tony barnhill Patriot 1500 Midget Headers Spridgets 3
A new headers Austin Healey 3
chrisc Wedge TR8 Headers/Exhaust Triumph 46
G I called Jet Hot about my peeling SS headers... Triumph 20
amcboy Headers, and what I intend to do about it.... Triumph 4
G Jet Hot coating peeling off my headers........... Triumph 9
T tvr 2500 headers TVR 0
Darrell_Walker Headers/exhaust manifolds for 4 cyl TR with Webers Triumph 12
73MidgetLigon Wrapping your headers is it worth it? Spridgets 11
S headers ? Triumph 20
G Catalyst location for a car with headers Spridgets 17
DNK E bay headers Triumph 0
G Removing my engine/tranny with Headers.... Triumph 4
T ok, lets talk about headers Triumph 9
T TriumphTune Exhaust Headers? Triumph 23
A TR6 Headers --VS.--Stock header??? tr6 Triumph 32
Brosky Pacesetter Headers Yes or No? Triumph 13
kodanja TR6 71' TR6 HEADERS Triumph 6
T TR4/4A tr4 headers-sizing Triumph 1
C Don... Those Headers? Triumph 11
M 'Kirk Racing Headers' need feedback Triumph 2
beez ceramic coating on headers Triumph 14
J has anyone used pacesetter headers and monza exhau Triumph 2
Morris Pacesetter Headers again Spridgets 1
