So I tracked down an elusive oil leak on my engine. There were small puddles on the flat recessed areas just underneath the sparkplugs. At first, I thought the usual which would be the valve cover gasket, but there was no oil on the upper part of the head. Pulled a plug wire and using a mirror, I found a threaded hole. Turns out, the six studs for the rocker assembly are leaking. What might be good for sealing those up? Hylomar, Locktite, anti-seize, or the old favorite, Teflon tape.
Thanks,
Greg
Thanks,
Greg
