MGA 1961 MGA 1600 engine help needed
TFR
A friend brought his MGA over because he said the engine made a rattling noise. Like marbles in the engine.
He told me that he just had the engine rebuilt and has had this noise since.
After listening to it it has some serious noises. They don't seem to sound like rods or crank bearings. However it does sound like a cam rattle and or valve train. Thought I would adjust the valves just to be sure. They were slightly loose but adjusting them didn't help.
I guess my question is:
Is the cam chain adjuster automatic or can it be manually adjusted? Does anyone have any ideas on upper noises an MGA might make?
I have a TR3 and am not familiar with the particulars of the MGA.
T
TFR
Thanks... that's my next step. Really hard to believe a newly rebuilt engine could make a such rattling sound. Hope your right and it is as simple as the WP or Gen.
bob67bgt
MGA's have a rivited front pulley on the crankshaft. Its not a upper end noise but check it with the fan belt off and see if thats where the noise is comming from. Also when installing a new timing chain tensioner it need to be activated. There is a small bolt that needs to be removed and a small probe or allen wrench inserted and turned. This will release the spring inside. Then the bolt gets installed and the lock tab gets bent over in 2 spots. I hope this helps! Bob
Platinum
It's been years since I fettl'd with an A engine so I can't recall how the fan is bolted to the pump hub... BUT: with a B engine the fan has rubber grommets and short sleeves at each of the four bolts. If the grommets aren't installed or are in poor condition the noises it makes sound like the engine is coming apart at the top end.
Can you not get your hands on a stethoscope or long screwdriver to listen to pump, generator etc. to isolate the region the noise is coming from?
<span style="font-style: italic">
EDIT: Bob's suggestion and info regarding the chain tensioner needs to be considered too.</span>
T
TFR
Can the chain tensioner be adjusted with everything assembled? Does anyone know of a good service manual for download?
Platinum
Tensioner is spring loaded and needs to be "activated" as Bob says, on installation.
There's this: Bentley Press
Not aware of a downloadable manual, tho.
I doubt it is the chain tensioner not unlathed, I took a engine aprt one time foir a rebuild, it had been smoking and was worn, but the guys was drivng it, took the timing cover off, it was a lte model MGB someone had converte to a double row and put a new tensioner on it, but they never released it, guy had been driving like that for years :smile:
I have a sound stethascope, but a mop handle can work just a swell, move it around to different location, and see if you can pin-point the area where the rattle is, you'll be surprised at how well that works.
MGZT260
Does the sound diminish or disappear upon pressing the clutch pedal? If so culprit is not in engine but throwout bearing.
T
TFR
Well have check all outside items. No help on removing belt, pushing clutch, adjusting valves.
Now going inside as deep as I can with out taking out the engine.
Bruce Bowker
Saw a V12 Jag engine that was "professionally" done that made noise. Someone had left a piece of wire in one of the cylinders. Amazing how much noise it could make being banged around and the tiny dents it left in that chamber.
T
TFR
Removed the head to see what is going on. Not sure if this is an issue but the pistons have an "F" on top which I think means "F"orward. If so they are facing the wrong direction. The other thing I see is that there are two verticle lines embedded into the number 2 and 3 cylinder wall. Probably from not checking the ring gap.
Have thoughts that perhaps the rods are facing the wrong direction maybe hitting something inside the engine.
Will update as soon as I find more to list
bob67bgt
On a MGA and early 3 main MGB the rods have offsets where they attach to the crank.(2 types of rods in there) I have never tried to install them in the wrong bores. I would think if the rods were in backwards they would probably not clear the cam. Bob
I believe the "F" is the grade of piston fit.
mark
T
TFR
What do you mean by "fit". Where would you find this information?
T
TFR
I just talked to a guy who used to run an LBC shop. He said that "F" is for reference to front and rear. That if the pistons are on the rods correctly the rods have to go in the right direction. This allows the rods clear the inside surfaces. May be my noise source... Let's hope.
not the first time i have been wrong, i stand corrected.
But i do recall looking thru a site *somewhere* that had piston listed by grade of fit....
mark
bob67bgt
As i remember the grade mark is in a diamond stamp also.I have not seen these on repro pistons just factory ones. I look forward to the answer to this problem when it gets sorted out! Bob
T
TFR
Well after getting the above post information back to the guy who owns the car, he has called the place who rebuilt the engine. They are willing to repair and correct the mistakes at no cost. The owner has cancer and I wanted to resolve it as soon as possible. So he has time to enjoy the car in case his prognosis (spelling) is poor.
Will have to ask them if my findings were the problem and the corrects done to resolve the problem.
NutmegCT MGA Motor Trend 1961 Review of MGA 1600 MkII MG 8
G MGA 1961 MGA MG 8
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S Wanted The Autocar December 1, 1961. Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
N General MG 1961 mg MG 14
kodpkd 1961 BT7 engine oil Austin Healey 31
Hamish Racing 1961 vintage car film UK Racing 6
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
D TR2/3/3A 1961 Triumph TR3a Triumph 17
T For Sale 1961 Austin Healey BT-7 for sale Austin Healey Classifieds 1
T For Sale Tr3a 1961 Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
Kleykamp For Sale 1961 Triumph TR3 Triumph Classifieds 0
R TR2/3/3A 1961 TR3A's Nuts, Bolts and Screws Triumph 5
P For Sale 1961 Bugeye Sprite Spridgets Classified 0
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
L For Sale 1961-1969 AH Sprite, MG Midget Chrome bumpers & hardware Spridgets Classified 0
I 1961&62 Mk2 sprite roofs Spridgets 1
G original radio 1961 e series jaguar Jaguar 3
S TR2/3/3A 1961 Triumph TR3A - Light issues...likely issue? Triumph 5
longbridgehealey 1961 Nash Metropolitan Spotted 2
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
arcom TR2/3/3A Decent 1961 TR3A on BAT Triumph 11
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
H 1958-1961 Austin Mini 850 speedometer housing pod British Motor Corp 3
R old [Austin Healy 1961 sprite] vs new [Peugeot 306] hill climb youtube[TopGear] video Spridgets 4
F Carpeting Austin Healey 3000 1961 BT7 Austin Healey 10
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
Italia 227 Post-War Other 1961 Triumph Italia 2000 GT – new member Triumph 19
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
Kleykamp TR2/3/3A 1961 TR3 turn indicator diagnosis? Triumph 4
Hot Wings 1961 Austin Healey 3000 BT-7 4 sale Austin Healey 10
C 1961 3000 Restoration Austin Healey 132
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
3798j TR2/3/3A My 1961 TR3 - Class of '67 Triumph 6
R TR2/3/3A Tr 3a,1961/62..anyone interested? Triumph 3
N TR2/3/3A 1961-TR-3 Transmission Fluid Triumph 4
N TR2/3/3A 1961-TR-3 Choke Return Spring Triumph 1
AUSMHLY 1961 Austin-Healey Sebring Sprite Lightweight Work Austin Healey 0
E TR2/3/3A 1961 TR3A Engine Color? Triumph 7
S TR2/3/3A 1961 tr3 conversable top rib color Triumph 7
P TR2/3/3A 1961 TR3 for sale On web Triumph 6
S TR2/3/3A gas tank in a 1961 tr3 Triumph 12
C 1961-1962 Sprite, What chasis and Frame? Spridgets 4
H CUMMINS TURBO DIESEL CAR 1961 PLYMOUTH Other Cars 2
