100 rear diff - nut torque
John_W
Hi guys,
I pulled the differential out of the rear axle pumpkin so I could make a new gasket to, hopefully, prevent the gear oil drip drip drip. I have it all back together but I have not been able to find any reference to the proper torque for the ~10 or 12 nut which hold it in. I assume that tightening the nuts real good will help prevent the gear oil leak at this joint but I really don't want to go too far and snap a stud.
Any ideas on proper torque for these nuts?
Thanks
John
zblu
probably just snugged up enough to sandwich the gasket tight, kind of like an oil filter today, ie, tighten up gently in a manner similar to head torquing then another 2/3 of a full circle so you dont crush the gasket too much
Those are 3/8" fine--24tpi I believe--studs. The nominal torque--from the charts--is 30-35 ft-lbs, which I've always used with no problems. If the gasket is thin paper--it should be--you can't crush it much. I put a thin skin of gasket sealer--I prefer Permatex Aviation Form-A-Gasket or Hylomar--on both sides of the gasket.
If you still have a leak you'll want to have a look at the pinion seal (under the U-joint flange).
R 100-4 rear fenders Austin Healey 6
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
andrea 100 S ?? on The rear of JAY LENO Austin Healey 0
andrea 100 S? on rear Jay Leno Austin Healey 1
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
simon1966 100 rear bumpers? Austin Healey 13
C AH 100 Best Options for front and rear suspension? Austin Healey 9
J Tracing the opening of a AH 100-4 rear fender Austin Healey 10
Trevor Jessie Bugeye rear ends 100-6 [the result video] Spridgets 12
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
longbridgehealey rear seat pans for 100-6 Austin Healey 26
Z 100/4 Rear Fender Potential Rust Area Austin Healey 8
mjobrien DWM Rear Seal for 100 Austin Healey 9
Bob Claffie Rear fender install[100/6] Austin Healey 3
beaulieu do 100-6 rear fenders unbolt ? Austin Healey 4
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 6
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 9
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
