100 Octane Fuel
aeronca65t
I went down to my local gas station to buy some 100 octane fuel for the race car. It occurred to me that some of you in the USA might be interested in locations for buying this stuff.
I realize that in Europe, Australia, Mexico, etc , it is possible to buy high octane fuel....but in America, it's hard to find anything better than 93 octane unleaded (and note that the octane rating system may be different in different parts of the world...in the USA we use the "(R+M)/2" system).
Anyway, here's a link for finding 100 octane Sunoco in the US (also known as "CAM2"):
https://www.racegas.com/gt100locals/gt100localsmainASP.asp
To be sure *most* of you do not need this, in fact most British sports cars can run fine on 89 octane unleaded fuel. Also, GT100 is $5.25 (USD) a gallon. It costs me almost $80 to fill three 5-gallon containers.
waltesefalcon
114 octane costs $4.59 here. I'm not sure who the supplier of it is, but I do know it is some great stuff.
Steve_S
I'd love to get my hands on some of that. My car runs very well on a 50/50 mix of 100 and 91. If I had 114 at a lower price I could do 60/40 and save money.
waltesefalcon
Steve, I typically add a couple gallons of the 114 to my spitfire when I fuel up. Thats about 70/30 and it works great for me.
G
We've also got CAM2 nearby, my buddy cuts in 50/50 with premium when he takes his Supra out to the track. I used to run the stuff occasionally when I was a kid in my Stangs and Chevy's, whenever I wanted to do big burnouts or other idiotic stunts. Seemed like the tires broke loose so much easier with that stuff in the tank.
A
aerog
I used to run 100LL in my VW engine from time to time (and I put all the test fuel I drain from the cessna in there too).
Dave Russell
Yoda - R.I.P
[ QUOTE ]
To be sure *most* of you do not need this, in fact most British sports cars can run fine on 89 octane unleaded fuel (R&M/2). Also, GT100 is $5.25 (USD) a gallon. It costs me almost $80 to fill three 5-gallon containers.
[/ QUOTE ]
So true. Using an octane rating that is higher than is needed to prevent detonation actually LOWERS power output & fuel mileage. Very few old British cars, or newer cars in general, have compression ratios higher than 9 to 1 & need higher octane fuel. The newer cars with compression ratios higher than 9/1 can run on 89 octane (R+M/2) because of the computer controlled engine management systems. A few of them will show slightly more power with a higher octane fuel as the EMS adjusts mixture & timing for optimum.
Additionally, AV gas is formulated to not vaporize too easily at high altitudes & thus isn't very efficient at low altitudes since it won't vaporize as well. It is rated on an entirely different system than the commonly used R&M/2 system used for automobiles.
The idea in our society that "more is always better" is hard to dispel, so probably some folks will continue to convince themselves that high octane is better. I guess that perception IS reality. Just because it may be needed in high compression special applications does not mean that it is better for all engines.
To each his own.
piman
Hello Dave,
as there appears to be differnet methods of calculating the octane rating, and as I don't know which the British used, does make comparison difficult.
However I know of at least one car that had a sticker advising that 100 octane must be used and that was the Rover 2000 (60's era) The high performance version of the Triumph 2.5, (Injection model) had 9.5:1 and I think the Hilman Imp had 10:1, Jaguars offered the option of 9:1 (8:1 being standard), but as you say anything over 9:1 was not commmon.
Alec
Dave Russell
Yoda - R.I.P
[ QUOTE ]
Hello Dave,
as there appears to be differnet methods of calculating the octane rating, and as I don't know which the British used, does make comparison difficult. Alec
[/ QUOTE ]
Hi Alec,
There are two fuel octane rating/measuring systems in use for auto fuel. (Aircraft ratings use another entirely different method.) The Motor Octane Number - (MON), & the Research Octane Number (RON). The pump octane number as used in the USA is the average of the two ratings. Eg. (R+M) divided by 2. European countries & the British use the RON.
The approximate octane "translation";
USA - 87____Europe - 91____RON - 91____MON - 82____R+M / 2 - 86.75
USA - 89____Europe - 95____RON - 95____MON - 84____R+M / 2 - 89.5
USA - 92____Europe - 98____RON - 98____MON - 87____R+M / 2 - 92.5
Since the fuel grades used from batch to batch are allowed to vary quite a bit, the results from different pumps can be noticeably different at any given time.
piman
Hello Dave,
thanks for that, and I have to assume that there was some good reason for the different measurement standards.
Alec
BlueRidge1
When I used to race at Hickory Motor Speedway in Hickory NC we used 116 octane turbo blue, used real cold spark pugs BL
50 or 60 was the number. Started out running a/c plugs but the compression would launch the porcelin part of the plug ,just blow em right out of the metal base. Had to swich to the yellow accel plugs ,they held up good. Bob
tony barnhill
Great Pumpkin - R.I.P
WOW! There's a place right down the street from me that sells 100-octane!
aero - what will I have to do to get my 3.4V6 SCCA SOLO II car to run on it? Or do I even need to bother?
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
T 100-Six Clutch Recommendations Austin Healey 5
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
H 100-6 Interior Installation Austin Healey 4
