Can somebody tell me why did Healey made the holes so big in the foot board for the pedals to go through, on the 100-4?
Anyway do the draft pads (black foam pads, with slots in them)get glued to the plates on the pedals or on the backside of the foot board?
There does not seem a good way with either option! If you glue them to the plates on the pedals, every tine you push in the clutch or brake you open the hole allowing cold air, or water in to soak the carpet. If you glue them to the foot board, first there is not a large area to glue them. Second I would think with the pedal rubbing on them it would not take long before they came unglued or ripped.
Has anybody done a mod to over come this? Like gluing rubber over the holes with slots in them to allow the pedal to go through?
Thanking you in advance,
Tod
Tod
