100-4 engine hardware
JRued
Specifically, looking for advice on rod bolts. Different advisors, different advice.
Option 1: Reuse existing rod bolts.
Option 2: Buy new from Moss/Victoria British
Option 3: Use 'close to" ARP bolts and machine the rods to fit.
What do you all think?
THX
John
GregW
Platinum
My connecting rods are different, but I went to ARP and they had bolts that fit with no mods to the rods. Maybe call them directly.
How is the engine going to be used?
If you're maintaining a stock state of tune, I wouldn't be concerned in the least about reusing good original bolts (check them for visbible damage though).
I would suggest getting new Nyloc type locknuts though.
For decades, we rebuilt Healey engines with the best used parts we could get our hands on, it's only the last couple dozen years that so much reproduction items have been available.
As for the repop rod bolts, I think I'd rather take a chance on the originals, than something that may've come from somewhere in China.
I've used the ARP hardware in plenty of BMW engines, it they definitely produce quality stuff, at a premium price.
Keoke
Option 1: Reuse existing rod bolts. :nonono: Never in your sweet life. Buy new or use uprated hardware.--Fwiw--Keoke
<span style="font-weight: bold">Option 1: Reuse existing rod bolts. :nonono: Never in your sweet life. </span>Buy new or use uprated hardware.--Fwiw--Keoke
I've got well over one hundred (>100) engine builds under my belt, the largest percentages being MGB, Big Healey & Spridget, and I have never-ever purchased a rod bolt. I've never had one let go either.
The BMW factory TIS stipulates that rod bolts on the S-54 (00-08 M3 engine) are not to be replaced, and that the same bolt be put back in the same hole it was removed from.
I'm thinking that BMW knows a thing or two about building engines__they started with aero engines over ninety (>90) years ago, waaay before they started building cars.
More opinions cancelling each other out; the OP may have to resort to his own intuition for this one. LOL!
musme
I used to buy rod bolts every time I rebuilted or even checked the bearings on my MG TD engine. On the rebuilt on my AH 100/4 engine I bought the bolts from Moss (over US200) and I found out that the original bolts are strong enough to be reused . I retorqued several times and they worked fine. You have to check that the threats are perfect and they are NOT like a spaguetti....
Keoke
:savewave:
There is a first tme to every thing.---Keoke-- :wink:
Deleted member 8987
And, using "new" bolts, might be a second and third.
Remember the First Rule of Automotive Repair, which states:
Just because it's a new part doesn't mean it's a good part.
GregW
Platinum
ARP is a pretty safe bet for quality parts. They are designed for stresses beyond what most Healeys will be put through. As a side note, when I showed my rod bolt to the guy at ARP, he knew it was from a Healey engine before I told him.
Keoke
Yep!! Greg, he probably sensed the last guy that tightened it Ether didn't own a torque wrench or did not know how to use one.--Keoke--- :laugh:
keoke, these cars have been around for lots of years now and there is no telling how many times the bolts have been reused in order to save a few bucks, perhaps if it were an engine for my grocery getter or a bmw id reuse some hardware but not on a healey that didnt have rebuild records, plus i hate pullin them engines out, it will cost alot more to do that then buy some new replacement bits.
GregW
Platinum
Hey buster, that'd be my dad yer talkin' about! :laugh:
I did have a good time razzing the old man about putting the clutch disk in backwards. That wound up rubbing half the heads off the flywheel bolts. :blush:
Keoke
Yep 7777's, remind me what the old folks use to say "Don't be penny wise and Pound foolish"---Took me a few mistakes to figure out what they was talkin bout. :smile:
Greg, I did that once too, and you what else it did it made the prettiest flat sided clutch disk springs you ever saw.
Keoke----- :driving:
glemon
Roger Menadue, Donald Healey's chief experimental (racing) engineer prided himself on never using a torque wrench. C'mon John, man up and reuse those quality British supplied bolts and tighten them by feel, and stop wasting time on these online forums and get back to work on the club newsletter. :nonono:
Greg
J
JRued
OK, no consensus. Best qualitative decision based on numerous sources...reuse the bolts, new nuts.
BTW: Nuts from Victoria British are sourced to Austin Healey Spares. Don't order any, though. I bought the last ones.
Thanks, all.
And, thanks, Greg.
Superwrench
I'd worry about the rods more than the bolts. I just magged mine and one is cracked. I will reuse the bolts after I mag them also. I will use Denis Welch or ARP nuts. Bolts stay tight buy stretch. Use a stretch gage and watch for .004 to .006 bolt stretch and they will run forever. Put the torque wrench away, you have no idea if you have any stretch with one. You are only reading friction between the nut and the rod.
I concur.
roscoe
Buy the best new stuff and forgetaboutit; or reuse the bolts with new nuts and tell everyone you got new stuff so you won't have to feel bad.....
R For Sale 100 engine block w/head Austin Healey Classifieds 3
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Dandare 100/6 Engine Backplate Austin Healey 4
W Looking for engine rebuilding 100-6 Austin Healey 12
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
E For Sale Austin healy 100/4 complete engine Austin Healey Classifieds 4
L First 100 Engine Serial Number Plate Austin Healey 13
T Austin Healey 100 engine color Austin Healey 10
D Engine 100/4 Austin Healey 10
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
A 1954 100/4 Engine specs Austin Healey 2
B 100-6 galley head engine - Do I feel lucky? Austin Healey 23
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
C Help!!! Austin Healey 100-6 engine problem Austin Healey 2
A 100 engine main bearing cap nut question Austin Healey 0
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
simon1966 The 100 engine Austin Healey 9
H 100/4 engine block Austin Healey 0
T 100 Engine Lifting Device Austin Healey 25
OZ_BN1 100/4 Engine Austin Healey 12
W Replacement frame engine mounts for a 100-6 Austin Healey 4
Z 100 engine/gearbox adaptor plate Austin Healey 3
andrea AH 100/6 Longbrige 1957 engine comp,Wiring Harness Austin Healey 9
H 100 Engine Timing Chain Tensioner Austin Healey 3
G Early 100/6 engine, automatic transmission Austin Healey 2
H Need Healey 100 engine parts Austin Healey 4
HEALEYJAG 100-M engine on EBAY Austin Healey 2
T 1955 100-4 Engine Paint Austin Healey 8
AngliaGT TR6 TR6 Engine - $100 Triumph 5
mbrooks 100 oil leak from front of engine Austin Healey 3
mjobrien AH 100 - Chassis and Engine Numbers Austin Healey 8
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 5
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
