Tri-Carb Project
Healey Nut
Healey Nut
Looks like I will be doing wiring on the weekend
Platinum
Artwork. Pure and simple!!
vette
I’m not able to see my BJ7 right now but I remember having this quandary also when I assembled the car years ago. And I can’t remember which way I ultimately decided. But I do remember that a factor that influenced me back then was water drainage. I believed that the eyebrow should go over the grill surround to keep water from running between the two.
vette
Looks like i lost track of time. Sorry about that.
Healey Nut
Healey Nut
Trying to tie up some loose end jobs .
seeing as I’m using an alternator to power all those rally lights etc I now have no where to mount the new coil …..so……
Make a custom coil mount bracket .
just need a longer bolt to go through the alternator mounting and it will sit basically in the same spot as it did with generator .
vette
I eliminated one horn then moved the remaining horn down to the diagonal brace
from toe box then mounted the coil on the vertical brace that the horns were on. Been running it that way for about 15 years. One horn is more than enough and I don’t think I have ever used it in anger.
Healey Nut
Healey Nut
I wanted to save space where the horns mount for my air compressor and “General Lee “ musical horn set up …………
Kiddddding ………😁😁😁
dougie
I never liked the coil mounted on/near the motor. The idea is to keep them as cool as possible and away from any heat source.
Healey race motor 5:17 5.jpg
dougie
Thanks Reid, keeping this one performing at a high level on track keeps me busy enough.:encouragement:
Healey Nut
Healey Nut
Carburation day coming up ,,,,,,,,, got them back from Apple Hydraulics all looking spiffy .
Healey Nut
Healey Nut
Dash is in wiring ongoing , instruments expected back soon . Cars are on , few details to deal with to finish the engine bay .
fire up day is getting closer .
dougie
Nice work, looking forward to hearing her run...(y)
Healey Nut
Healey Nut
Got the new gear reduction starter installed and have been able to spin the motor with all the plugs out and no fuel pump .
was able to make oil pressure and get oil to all the rockers and shaft etc so that’s a big thumbs up .
instruments are on the way back to me so fire up day for the old girl is closing in . Just need some new ignition bits and some fuel .
twas_brillig
I'd gone back to work about the same time that oil last was a hundred bucks a barrel and our BJ7's paint job from the 1980s was bubbling. Upshot: a lot, lot, more than a paint job.
Fenders had a swack of fill that we didn't know about, and the question was: steel replacement fenders, or clean up the originals? Made a guess and bought replacements, and they took a lot of 'fettling' - might have been a better idea to rework the originals, but you never know. It all took man-hours and skill.
The car turned our really well (body and various mechanical upgrades etc. etc.). I can't justify the money that the project absorbed, but it sure made sense for me (since I was able to 'unretire' for this second time) to turn my personal man-hours into getting paid, and ship the money to the shop. I can justify my man-hours in the office, as the end result was vastly superior to me spending the same hours, sitting in the garage, overwhelmed.
The car is sure amazingly done!
PS: 'rally pods'? On our Sprite, we call them 'bugeyes'......
Healey Nut
Healey Nut
That’s because it’s a Sprite and not a mild recreation of the works Rally cars
Healey Nut
Healey Nut
More progress . Electrical almost done , just the indicators/side lights to mock up and test . Instruments all in and checked along with panel lights etc 👍.
Final check of ignition timing etc , fuel and fire er up coming soon .
And as an FYI that’s a 14” wheel and boss from SC spares in the UK .
Yes I know the wheel is on backwards , will fix it tomorrow ☺️
Editor_Reid
Platinum
Congrats on the progress - looking good!
However, before anyone else mentions it, you know, you have the steering wheel mounted backwards. The grooves/scallops in the wood, on the rim, that are currently facing the driver are actually meant to be finger notches (sorry if I don't know the technical name for them) and they're meant to face the instrument panel. There's no law, that I know of, that says you can't mount it the way you have it, but you're likely to encounter a lot of people who comment on it and ask about it. Maybe you're OK with that.
Healey Nut
Healey Nut
Oh crap, now I checked the pic again you're right. I was so happy to get that trafficator and wiring in along with the gauges, etc.,
plus I was conference calling at the same time with my daughter. Guess I will have to quit multitasking ☺️
Tks for the heads up.
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
