Tri-Carb Project
HealeyPassion
All sounds good! I love what you've done.
I didn't use full depth vents either. Since my guy custom made the vents from my patterns from Pat Moss's car, we, like you, thought they looked better not quite so large (deep). See pics.: Shows full depth original Works vents housing on left with my shorter custom housing on right. Of note is the carb access panel
That said, we liked the airflow improvement with the upper footwell reshape so added that.... earlier pics.
On the oil cooler ducts, we also discussed the dissimilar metals issue. My guy, who I've worked with on projects for some 30 years, was confident he has a permanent sealer that would make this a non-issue.... so installed and sealed them up. I guess if he's wrong I won't be alive to worry about it ;) .
Healey Nut
Healey Nut
Now the fun can start , or it will do once I get it home and some cars get picked up to make some working room for me in my shop . Paint and black epoxy needs a few days to harden up fully before bringing her home .
So that’s the 2012 Toyota Blue .
Healey Nut
Healey Nut
Lockdowns, broken ankles , forced time off work ......
A couple of winter resident cars have gone home so it’s time to get building . Just waiting on an order of parts from AutoFarm and I can start wrenching .
Healey Nut
Healey Nut
Haven't posted progress in awhile so here’s a few pics .
I have had that rally duct in and out more times than I can think of . It was a pain to fit and AH spares (where it came from) were no help at all.
It fit in the body only mock up but once the steering box was in there was no way it would fit and look right .
I ended up taking it all to pieces and fitting each piece individually. The main problem was clearance for the steering box , hence the custom bulge on the drivers side intake to clear it .
Maybe the rally cars had different steering boxes or they just jammed the duct in and we’re not as fussy as to how it fitted or what it interfered with .
The duct sides now sandwich between the lower rad mounts using the same bolt holes .
Just some final cosmetic tweaks and it can all be scuffed with wire wool then clear coated ready for final assembly.
My next challenge is the oil cooler ,it will go in front of the rally duct behind the lower custom shroud openings mounted between the front frame rails ,and then I will create an opening in the lower angled panel portion of the rally duct so the air flows through the oil cooler then through the lower portion of the radiator .
waiting on my minilite wheels from the UK then the driveline can go in and I can start refitting outer skin on her .
Jerry
Progress looks good! I should have put the oil cooler into the front like yours. I did not do the rally vents either, at the time, I was building our house and was too busy for the customization.
Only one of my cars did I do ALL the modifications that I wanted. And that was an old mini. I can safely say that I now have twice the cost into the car vs the value on the market.
Healey Nut
Healey Nut
Why would you do that?
The air has to go somewhere if it’s a blank panel behind it then the oil cooler won’t cool much .
Healey Nut
Healey Nut
So a couple more shots , my custom bump is all smoothed out . A shot behind shows why it had to be done to clear the steering box .
Im having second thoughts about the oil cooler location
Below the duct where the white writing is on the panel behind the crossroad with a slot for airflow cut basically where the white letters are or above where I have it standing with holes drilled for the hoses from below .
Healey Nut
Healey Nut
More progress . , getting there slowly .
I did some surface prep on the shrouds on the outside to about 70% done , they have gone back to my paint guy so he can paint the inside and get them to 90% outside before going back on the car .
I did resolve the cross rod issue , Boy racer was absolutely correct . Steering arms were upside down ie reversed etc .
Healey Nut
Healey Nut
Havent posted in a while , been busy . Anyways heres a few pics .
I was hoping to have rebuilt carburetors and instruments by now but Covid has put a dent in those plans .
Healey Nut
Healey Nut
More progress , front and rear shrouds on , rear fenders on but need tweaking . Scuttle scoop done . Oil cooler etc all done .
dash stripped and recovered , checking all the switches and stuff this afternoon prior to reassembly .
Instruments have gone to West Valley for repair/restoration , carbs have gone to Apple Hydraulics for overhaul .
it’s beginning to look like a Healey again . 👍
Healey Nut
Healey Nut
That all looks great - first class! Congrats on the progress.
Please pardon me if this was already covered somewhere, sometime, but the scuttle vent, is that for cockpit ventilation?
Yes , the car will have the original factory hardtop on all the time so ventilation is the key . If you blow up the pic you can see I have installed two of the rubber boots that are used on top of the heater box , they will have hoses directed down into the footwells .
Im going to fabricate a small picture frame with mesh insert to add to the front of the intake . I will carry a roll of masking tape in the car so should I get caught in the rain I can mask it off to stop the water getting in .
Healey Nut
Healey Nut
Got another milestone done today . Been putting this off as it required me to drill holes for nutserts in the shroud .
Anyways I waited a year for those rally pods from Dave Hardwick but I think it was worth it now .
PS the jig for alignment is Patent Pending 😁.
Now I can finalize the work on the trim rings I made/modified and get them rechromed .
The rally look is coming along nicely . 👍
Healey Nut
Healey Nut
Wheels with brand new boots going on this weekend (195/65x15s) so I can do the roll test to get my speedo calibrated .
Going to have to get my calculator out as there’s no way I can roll the car 52ft 9 1/2” etc etc as it’s minus who knows what temp outside and lots of snow . So it will be see how far the car goes over one revolution and extrapolate it out .
will post pics of them on the car soon .
HealeyPassion
Healey Nut, been a while since i visited this thread....delighted to see your progress!!
I'm also making progress... engine running well on a stand in the shop.... body work modifications are done, primed but not painted ... . chassis modifications done, albeit the chassis needs media blasting and painting. Nevertheless, progress. I took the differential in on Monday to be rebuild and swap in 3:54 gears (of course you know, the originals are 3.9). Sorry I didn't see this earlier, I have a set of rebuilt tri-carbs I might have parted with for your build. Oh well, I like them on the shelf for ???.... who knows why??.. right next to the original tri-carb manifolds!!??? Some things just aren't easily explained.
By the way, I love the jig for the rally lights!... perfect....I'm confident the patent will be approved.
dougie
I'll be performing at Laguna Seca Raceway April 21-24th during SVRA's Tran's Am Speedfest > 2022 Trans Am SpeedFest | SVRA <
if you want to see a tri-carb Big Healey in action competitively......
My "break-in" event this fall with the new motor at UMC in Salt Lake City went well......:cheers:
Healey Nut
Healey Nut
That would be something to see Dougie, but with border restrictions, etc., etc., I doubt it will be happening for me.
Healey Nut
Healey Nut
Wheel alignment done using my Pat pending method , new boots on ready for speedo calibration roll. Once she’s had the brakes bled and off the blocks .
shes looking like a little rally car now
Healey Nut
Healey Nut
Got the car down today to do the roll test for speedo cal . Stance of the car shows now with lowering kits front and rear .
It actually settled a bit lower after all the back n forth rolling . Going to need to buy an extra low profile race jack for this one .
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
