Locknut - rear wire wheel - torque spec?
SteveHall64Healey
Can anyone shed light on the locknuts which hold the rear hub extensions in place (for wire wheels) ?There are 5 on each side, and they are made of a metal that is softer than steel (maybe to bridge dissimilar metals without corrosion?) and have what appears to be slits cut radially into the shanks. Moss part number 031-294.
They look like they might crush when installed. Is there anything special about installing them and does anyone know the correct torque for these nuts?
thanks
steve
They're called 'prevailing torque nuts.' Nothing special for install, except make sure the threads are clean so you get an accurate torque reading. Tighten in a star pattern, like you would lug nuts. I believe the spec is usually given dry, decrease a little if you oil the threads. Nominal for 7/16" studs is 75lb-ft, I've always cranked them to 100 (barely perceptible movement from 75). I've also reused them many times with a little blue threadlocker, which IMO is at least as effective as mechanical means. 140K miles or so with no issues.
steveg
IMO Bob is correct about using the blue threadlocker (loctite). IMO using anti-sieze on them is not a good idea as you want them to stay in place. The anti-sieze is working against what you want to do.
I'm actually schizophrenic about this; I used anti-seize for years with no issues, using a little less torque as Randy suggested. If I reuse a torque nut I usually use threadlocker--clean the anti-seize off first--with more torque, as threadlocker has less lubricity. The idea is the strength of a fastener is from the stretch, and clamping power, of the bolt, not the friction, or lack of, of the threads. But, threadlocker has worked well for me in other places, like front shock bolts, and I use it and lockwashers on things like driveshaft yoke bolts. FWIW, I've never had a failure using any of these methods.
British_Recovery
Bronze
For more information, go to trojansf.co.uk. In their products section select "all metal prevailing torque nuts" and scroll down to the photos. You will see the nuts used on the Healey.
bob hughes
No anti seize, no thread locker, a good tighten as per an ordinary wheel nut is all I give them and I have not had any issues over the years.
:cheers:
pan
My 100 has a spiral bevel axle with four stud hubs but I have modified the hubs and fitted hypoid axle press-in studs. Being a bit paranoid about thes studs myself, but finding no specified torque figure I tightened mine to 60 lbs/ft. I figured an even tension was as important as the actual torque.
Recommended torque values are all over the place, but here's a credible source (for bolts; I'm presuming studs would be the same):
https://www.engineershandbook.com/Tables/torque.htm
I have pamphlets that came with my torque wrenches--I have three, for different ranges--and IIRC they pretty much agree with this, but have different values for dry or lubed. My tire shop always torques my Mustangs lug nuts to 100lb-ft, but they might be 1/2". 100lb-ft is on the high side, but I've never snapped one in over 200K miles on my BJ8. Of course, even distribution is critical, as are clean threads and surfaces, but it seems anywhere from 60lb-ft to 90 or better works.
S
SteveHall64Healey
That table is a great resource - thanks.
I went with 75 ft-lbs, dry with blue thread locker on these bolts. So far, so good.
steve
BJ8Healeys
The nuts are self-locking and should not be re-used too many times. I did that and had all five nuts on the left rear loosen during a trip. Before I realized what was happening, the movement of the hub on the studs necked down the threads. When I replaced the studs, I had the old ones tested at the materials laboratory at work and learned that they are Rockwell C32 - C33 hardness (equivalent to Grade 8). The max torque specified in standard torque tables for a Grade 8 7/16-20 bolt is 78 lb-ft. I torqued my new nuts to 70 lb-ft and marked them with "witness marks" to indicate if the nuts were moving and losing torque. None of them ever did. Loc-Tite is not necessary, nor antiseize.
S
SteveHall64Healey
This is really helpful Steve. I’ve been cautious about re-using the nuts too many times as well. The current set (not cheap!) have only been torqued into place twice now. The previous set were rounding off at anything approaching 70 ft-lbs, so were replaced. The quantum of contact area between nut and socket in situ is low, making round-off relatively easy.
1 Removing a frozen tie rod locknut MG 15
Velox Alignment question - cross tube locknut release? Austin Healey 29
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
drooartz Bugeye jack points to remove rear axle Spridgets 18
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
