Deleted member 21878
i was wondering if anyone could tell me from the pic below if this is a newer radiator core.
back when i was putting the motor together i took the radiator to a local shop to check out. he said at the time that someone had put a new core in it. there were no leaks and the radiator had great flow.
i am still running hotter than i would like so if the core is the newer style, i will look to add a pusher fan this fall.
Thanks
Thanks
