T-Series SU fuel pump fun
NutmegCT
Just wondering if anyone can advise, or point me to troubleshooting sources, on my Type L SU fuel pump.
Issue: no more steady click/ticks. Just a rapid fluttering/whirring sound.
Thanks.
Tom M.
Flash_Harry
Dave DuBois - on another forum - has this article posted on SU fuel pump troubleshooting:
https://www.mgexp.com/article/fuel-tsg.html
Not sure if he still does refurbishment of SU pumps, but this should get you a start on the problem.
Harry
NutmegCT
NutmegCT
Thanks Harry. I just contacted Dave D.
Problem is probably the old (original) diaphragm, which I could replace myself. I'll hear what Dave has to say.
Tom M.
Platinum
Diaphragm compromised by that demon ETHANOL.
NutmegCT
NutmegCT
Ethel who?
Photo of the diaphragm:
PAUL161
Might make a nice wall decoration, for a remembrance piece! :highly_amused:
pdplot
When in doubt - change it out.
With the three TDs I had, none of them had any SU fuel pump trouble. And the Mark II had 2 of them. If it kept clicking, you had a fuel leak.
Platinum
Now that it's apart, change the diaphragm. The membrane appears to be intact but the cloth re-enforced rubber part looks dead.
As pd has said, there's something else wrong. Look to the carb's float bowls and needle valves, including the floats themselves. Pull the line from the carbs at the supply pipe and block it off, turn the iggy on and see if the pump slowly stops clicking. If not, start looking at the line from tank to pump for air leaks and consider the idea the in-tank pickup may be rusted (pinholes). Fill the tank and see if things change.
NutmegCT
NutmegCT
Thanks Doc. I'll replace the diaphragm soon as I get the old one out and can measure it. There are two sizes (3" long and 2 3/8" long).
Here's "the rest of the story".
After draining and washing (and rinsing and drying) the fuel tank two weeks ago, I hooked up the lines to make sure there were no clogs or crud anywhere in the fuel system.
Ignition on, pulled the starter switch. Cranked it up - engine started fine and dandy. But died in about five minutes.
Cranked again - started fine, but this time it died in a few seconds.
Then I noticed that when I turned on the ignition, the SU pump didn't click. Just "buzzed" or whirred.
Oy - must have a clog inside. Disconnected the line from pump to the carbs, ran the pump - nothing came out, and the pumped just whirred and fluttered again.
Removed pump. Girding my loins, I pulled it, opened it, and blew air through the inlet and outlet. Diaphragm looked dodgy, so went through the fun of trying to diagnose if it had just gone bad. Being a complete dolt (dotard?) about SU pumps, I was treading carefully. But other than the wrinkled appearance of the diaphragm, pump seemed ok. Gave it 12 volts, but it still just whirred without clicking.
Decided with the pump off, I'd check for crud in the fuel bowls. Managed to get the bowl tops off, removed the floats, cleaned the bowls, reconnected everything.
Ignition on, pump just fluttered again. Didn't pull any fuel through the line; bowls stayed dry.
Well, maybe there was still some crud at the bottom of the fuel tank that had lodged somewhere in the fuel line.
Blew air through the line - noop - no fuel line clogs.
Want to guess why the pump was whirring and not pumping fuel?
:jester:
Platinum
The pump's points.
JPSmit
Well there is a first for this site :rolleyes: well spotted
pdplot
My dad's answer to a tv or radio problem- "Are you sure it's plugged in?"
Not as bad a problem as failing to put oil in after draining old oil.
Platinum
'k Tom, you now owe me a keyboard.
Platinum
My lesson unlearned is; that you can't leave the dizzy rotor on the bench and expect the thing to start. I relearn that one more often than I'd like.
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
