BT7 conversion to alternator
  • Thread starter Deleted member 21878
  • Start date
i have been reading posts and articles on the conversion. i want to use my voltage regulator so i wired today as i have seen in these articles. just wanted to make sure this looked right to you all. basically A1 terminal has the blue/brown wire; A terminal has the yellow wire from the alt and the two brown wires; the F terminal has no wires; the D terminal has the yellow green wire from the alt and the smaller yellow wire from the dash light; the E terminal has the black ground wire.
few questions:
do i need to run any other wires for the conversion? obviously i need to connect the ones to the alternator when i finally get one. i thought i read somewhere about getting a three wire alternator so wondered where the other wire went. not sure i saw anything about that.
this is a new wiring harness. are the wires in the harness heavy enough?
last, i read a lot about the wiring but not really how to place the pieces in the contacts so they can not connect. i used wire shrink to isolate the connections. i slipped one over the verticle bar on the right, isolating the front and the back of it. then i slipped another piece behind the contacts next to the coils. is this enough? anything else i need to do?
No engine in yet so i can do most anything necc without much fanfare.
Thanks
Oh one good thing learned today... My steering wheel button and my voltage regulator cover were quite dull. after cleaning and trying a few different ways to polish, i still was not happy with them. So i tried some S100. it did a great job on both. going to hit the gearshift knob tomorrow.
steveg
I used to be in favor of the 3-wire alternator, but now I favor the 1-wire version in combo with a voltmeter. The no-charge light is too small to see anyway.
The big wire from the generator seems to be a 12 ga. Maybe not good enough at high speed. I ran a separate 10 ga from the alt to the battery cable mount on the solenoid. The big yellow if used, connects to the big brown wire from the solenoid. There are multiple threads here on how to connect these. Your pic may not be quite right.
Also see https://www.healey6.com
vette
The terminal strip in my drawing is the layout of the screw terminals on the voltage regulator. Your wires should be connected exactly as are shown on my terminal strip. They are from the left, the Brown/Blue wire, the next terminal would have a large Brown with a large yellow wire, the 3rd screw from the left would have nothing on it, the fourth screw from the left would have the smaller yellow/ green wire (may drawing accidently shows it as a small yellow/brown) this fourth screw also has the small yellow wire from the ignition warning light on it. The last terminal on the right is just for a black ground wire.
Now you have to realize that on the left the Brown/Blue, the Brown and the larger yellow all have to be tied together, that is why i show a jumper on the two left most terminals on my drawing. I do not remember how the voltage regulator in internally connected so it is my opinion that all the internal connections to these voltage regulator screws must be cut away from the terminal screws. The only wires that are to be touching each other are the ones on my drawing. In your picture it appears that at the minimum you do not have the two left terminals tied together which would connect the Brown/Blue, the Brown and the Heavy Yellow.
Also, the wires in the original harness are not large enough for an alternator. It will electrically work but it is a hazard. I believe the largest wires in the original harness are #14. They may be #12 but even #12 is not large enough. This is why my preference is for a 3 wire alternator. Because the 3 wire alternator has a stand alone "BAT" terminal. this is the output to the battery. I run a #10 wire from the alternator "BAT" terminal to the "BAT" terminal at the solenoid. This then is the direct connection between the alternator and the Battery. Even a #10 could theoretically be too small but it is a good compromise in the it will carry between 30 and 40 amps. (yes I know it is not rated for 40 amps but it will carry it. and it will carry even more for short periods of time.) The original wire in the harness is rated for 20 amps max. Most Alternators are capable of putting out at a minimum of 60 or 65 amps. Some older ones may be only 45 amps. Anyway, this is not to be looked upon as that your car's equipment will never pull the rated amps of the alternator. The fact is that if your battery is in a low state of charge, or as such, is old, or just out of storage, etc, the alternator will put out up to its max rating to try to keep the battery up. This will easily overload the original wire in the harness. So put at least a # 10 wire from the alternator "Bat" terminal and the solenoid "BAT" terminal.
Edited, last terminal on right is ground wire.
vette
it seems the only thing i am missing is the jumper wire between the A1 and the A terminal. i would assume a 16 gauge wire is fine for that.
i also have the brown wire that goes to the horns on the A termninal as is on the original diagram.
Now i thought that in multi-strand wire that the rating for wiring is like this: 16 ga / 20 amp; 14 gauge / 40 amp; and 12 gauge is 60 / 60 amp. (depending on length of run) i know in house wiring which is single strand that 12 guage is rated at 20 amps but i thought multistrand was different. guess i need to look that up again.
either way i may as well run the extra 10 gauge wire to the solenoid. simple enough.
as always, thanks for the help
steve
you say "the big yellow if used"... does this mean if i run the 10 ga back to the solenoid, i do not need the big yellow? in vette's pic it appears he uses both.
Steve
so you put the brown/blue right on the same terminal as the brown to save the jumper.
no ground needed I assume since it is just a junction.
And I would guess only the right side of the voltage regulator needs to be isolated?
vette
Say Drone Dog, You don't want to do any guessing here. I want to caution you to not mix and match different concepts here from other posters. I'm not faulting anyone, I just don't know what other types of alternators that others might have used. If you hook it up the way I showed it with the type of alternator I used I know it will work fine. as far as eliminating certain wires then make sure you do it with the same equipment that is used in that scheme. I also want to restate that internal connections in the original voltage regulator would change everything that I have on my drawing so if you do it as my drawing shows you must make sure that nothing else is connected to those wires except what I have shown.
Also, a #16 wire is not large enough for the jumper that I have shown. The Brown/Blue wire and the Brown wire have the heavest load of the whole harness on them. Make this wire at least a #14 and a #12 if possible.
Makes sense. So get my equipment and then set up my wiring accordingly.
you have a three terminal. Is that a Delco unit?
i am am thinking a Hendrix mount and then buying an alternator to fit. Current plans anyway.
steveg
DD,
For the purpose of figuring this out, suggest buying a terminal block at the electrical/home store. Use that instead of the regulator. That way you're not destroying the reg.
The pictures I've posted above directly reflect the Hendrix kit instructions. IMO these are the simplest way to hook up the alternator.
The 10ga wire direct to the solenoid is most effective because going to the connection block then jumping to the brown wires puts all the current at high speed through the brown wire from the block to the solenoid connection.
PS - those instructions also state you can use wire nuts to join the wires. This would suffice as a very temporary solution while you figured things out.
I'd advocate use of a voltmeter over an ammeter as it is installed in parallel on your switched ignition circuit, rather than in series as the ammeter, which requires heavy wires with full current. Flame away.
vette
Drone Dog, just to answer your questions to me, I am using a AC Delco alternator of approximately 1994 vintage. My alternator mounting is from Hendrix. I also recommend to NOT use an Amp meter. Even thou it can be installed in a safe manner (many vintage cars had them, including my 1970 Corvette which has not had the meter or the connections changed for over 30 years), the Amp meter is not as helpful as a voltmeter.
Thanks for the info. I did some reading last night on alternators and have a much better understanding of why yours, and steve’s System works. Should probably have started there first before worrying about the voltage regulator. I do like the look of it being there so I will work it out.
Thanks again.
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
J WEBER conversion on my BT7 Austin Healey 26
6 Dash Instrument Conversion: BJ8 > BT7 Austin Healey 3
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
