TR4/4A Replacing Drive Train Seals
TBU_Triumph
We're continuing our rejuvenation efforts on the 1966 TR4A. Overall it is in decent shape for a 50 year old car with 70,000+ miles.
I am debating (or arguing) with myself if I should replace some key seals in the drivetrain. Specifically I am looking at the transmission input shaft and output drive flange seals as well as all 3 seals on the differential (IRS car). The only ones that show signs of leakage right now are the differential input shaft and the right side drive flange.
Based on experiences form forum members am I creating more problems by replacing them or should I leave those that are not leaking alone? My concern is not the level of skills or tools needed to do the work. We have that well covered. Plus the transmission is already out of the car and the diff will be in a few weeks.
Thanks,
Rusty
Mink
Thanks,
Rusty
I replaced mine and I'm glad I did. The originals were rock hard/brittle.
TR3driver
Great Pumpkin - R.I.P
I'm usually with the "if it ain't broke" crowd, but IMO if the transmission is already out (and still has original seals), it would foolish not to change them. They're easy to change (with it out of the car) and modern seals are almost never defective. Check the surfaces that the seals run against too, sometimes the original seal has cut a groove that can cause a new seal to leak. If you can't polish away any marks, consider installing a Speedi-sleeve.
T
TBU_Triumph
Thanks for the guidance. I definitely will replace the diff seals. It is pretty much coated with grease and crud. The car has been sitting quite a while so I expect that will start leaking more when it goes back into service.
I'm still debating about the trans but am leaning towards doing it just because it is so little work right now. It is obvious that the transmission has been out of the car but we suspect that was for a clutch job. Whoever did that work hammered on the end of the output shaft (not sure why) so much that I will have to remove the burr to remove the nut.
And thanks for the reminder about polishing the sealing surface. There is one trick I have used successfully when the old seal has cut a groove in the shaft. If there is room in the installation I will install a spacer ring in front of the seal so it runs behind the prior position. You cannot always do that do to the space limitations.
Rusty
Brinkerhoff
Full speed ahead I says. I think 50 years is plenty before they need to be taken right down and built back up. That way you'll get a closer look at the u joints , mounts , exhaust etc.
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
