Hi,
I just rebuilt the overdrive that wasn't on my car and found a OD type tranny main shaft. I just pulled the tranny and am ready to disassemble and switch main shafts. Any good instructions for swapping out the main shaft with minimal disassembly? I have rebuilt engines but never a transmission. The transmission has been shifting fine. The OD main shaft cam for the OD pump fits on snugly but is not a press fit. What holds it in place? Also, are there some things I should absolutely do when I have it apart?
Thanks in advance.
Regards,
Chuck
PS I do have a B.M.C. workshop manual.
Thanks in advance.
Regards,
Chuck
