I need to add oil to the ZS dashpots....
What type/weight oil do I use?
As always, THANKS!
As always, THANKS!
I believe that is in the factory owner's manual for the TR3, which also specifies different straight weight oil for different temperature ranges.Geo Hahn said:I have heard a rule of thumb 'use the same oil as you have in the crankcase'. Perhaps the notion was that then you would be using lighter oil in cold areas/months and heavier oil in warm areas/months.
