Geo Hahn said:I'm using that extra 2 gallons on everything but pancakes.
Geo Hahn said:There is no end to what people use in the carb dampeners -- ATF, motor oil, Marvel Mystery Oil. The difference, of course, is the weight of the oil and what works best may depend in part on temperature, condition of the engine, what you expect, etc.
I suspect that there is little perceptible difference between ATF F & FA for what you are using it for.
TR3driver said:Also FWIW, although the difference was relatively subtle, there were distinct differences between various "weights" of oil in the carbs and how my 59 TR3A (with SU H6 carbs) responded to the throttle. Contrary to what you might think, heavier oil actually produced a sharper throttle response, while thinner oil made the engine seem sluggish. I found that 20 weight motor oil produced about the best response for me. Thicker oil actually made it somewhat difficult to apply throttle smoothly.
