rblackadar
Hi all! I'm new to these forums here. I was wondering how you basically set up the twin carbs if I don't currently have the carb. tools. I'm just trying to see how the car runs. I bought a rust free 76 TR7 Victory Edition that would run when starting fluid was put in but would soon die right after. I have done the following. Rebuilt carbs, cleaned the filter element in the fuel pump, replaced all vacuum lines and fittings, all new rubber fuel lines(at least in the engine bay), Rebuilt the air pump ( yes it is staying completely stock)new wires and plugs. I also have a fuel filter that I haven't fitted yet. I tore apart the alternator and cleaned the rectifier of rust and dirt with a wire brush and then coated everything with dielectric grease. I've cleaned all ground points and coated them with dielectric grease as well. I'm just trying to get everything like this done so when I start it for the first time I could decrease the possibilities of any problems. I'm going to take the engine out this winter so I can send the shell off to get the front strut tower replaced. /ubbthreads/images/graemlins/mad.gif(previous owner nailed a curb I believe, which popped the welds at the top of the tower away from the top of the fender rain channel. There is about an 1/8 inch gap between the panels at the top...) I do have a rust free front end coming in from Arizona to replace the damaged pieces. Then she gets stripped and painted the original color of Pimento red when she is done. Whew!!! Sorry if I rambled, there is just so much I have done and got to do. I'm still learning about these cars. Any insight is appreciated. Cheers! /ubbthreads/images/graemlins/cheers.gif
