V
vagt6
I found a rather nicely restored '74 MKIII Midget on Hemmings with a long list of engine mods, listed below. It's listed on Hemmings, located in Arlington, VA.
I'd like input from engine gurus on the driveability of such and engine: is this a good street engine?; Do you see any anomalies with the list of mods, below?
Your comments, please:
<span style="font-weight: bold">Engine:</span> Isky lifters, pressure plate, cylinder head machined to 0.0600, āmildlyā ported, 3 angle valve job, Rim Flo intake and exhaust valves, competition head gasket; Winner Circle timing chain and gear kit, bored to 0.020;ā Cooper āSā pistons 9.8:1 compression ratio, VP7 Performance camshaft ā 103 degree BTDC @ intake full open, 0.010ā over main bearings, standard rod bearings, new cam bearings; polished aluminum head cover.
<span style="font-weight: bold">Drivetrain, Etc.: </span>Distributor, header, other engine parts during rebuild including vacuum advance, radiator core, ANSA exhaust, competition header, brake pads, cylinders, shoes, rotors, water pump, master clutch and slave, master brake cylinder; Rivergate 5 speed conversion (Datsun B210) transmission, ring gear, Rivergate speedometer conversion kit, special driveshaft yoke and U-joint.
The rest of the car seems extremely nice. New paint; tube shock conversion; disc brakes; leather seats; Minilites; much more. Price seems in line with the current market values, maybe a little low.
What do you think?
Thanks, guys!
What do you think?
Thanks, guys!
