jlaird
About three miles on car now, no rear seal leak. Not sure I beleive it either.
However, I do not have a forth gear. Think I got a ball bearing in wrong, duh. Need to read up on that. It was the first time I ever had one come out.
Will take it to the car show as it is and continue driveing it around Blue Water useing third gear just to check and double check that the leak is gone.
What I did, noted that the bottom half of the scroll seal can not be adjusted or moved as it is cast as part of the rear main bearing cap. But did note that the top half although not adjustable other than the slop in the bolt holes. Noted that someone said the fix was to use jbweld and kitchen plastic wrap to make it tight.
I laped the ends of the top seal with sandpaper on a flat surface, supose I might have taken off several thousands. When I bolted it back on I used a bit of gasket maker on the back and just a finger wipe on the bottoms where they mate with the cap seal. Used a C clamp to make sure it was down as far as it would go as I tightened it up.
Will find out over the next few days if indeed the leak is gone or the seal is in fact a seal.
After the show next weekend, out it comes again think that will make 7 times still not happy with second gear, remains a bit stiff.
