The ignition amplifier furnishes the signal to the coil to initiate the high energy spark for each plug and it also furnishes a timing signal that is used by the ECU to turn on the fuel injectors at the right time. Yes the aluminum amplifier effects park plug and fuel injector performance. From what you say I would bet that your ignition amplifier is the cause of your problem(s). Since I cannot bench test your ignition componenets, the only choice you have is to get a replacement ignition amplifier and see if it solves these problems. If you think your spark plugs have become fouled due to the irregular running, you might have to clean and adjust them or replace them in order to get the engine to return to 12 cylinder opereation. The other potential source for problems such as you are having is the trigger sensor in the distributor. Usually a continuity check through the leads to this sensor will verify its performance. It is not as vulnerable to heating failure as the ignition amplifier insides are. I cannot tell you whether your earlier aluminum amplifier is repairable since I have never had occassion to open one up. They are very rare in the USA. In an XJS as old as yours, it is possible that your ignition system has previously been adapted to an after market system. Check to see if the ignition amp is a Jaguar part. It should have Lucas identification on it. Do you have Jaguar serevice or repair near your location in Spain? Best regards, Jack Farrington
