middleagecrazy
Yesterday the wifes 2003 X Type started fine and I backed it out of the basement. Shut it off and then pulled my 69 Sprite out. I then got in the Jag and it would not start. Just a click. I got the jumper cables out and found that the ground post on the battery was corroded. I cleaned the battery post and got it started. It was driven to the Church then to my sister in laws then to the grocerie store each time starting without any problems. This morning the wife calls and says it will not start. When I get back to the house the car is still in the basement and the wife has disconnected the battery. She said check this out and put the ground cable back on the battery. Every relay and light in that thing started flashing. Even the trunk light was flashing. I talked with some of the guys here at work and most have said it is a ground problem with the ECM. Anyone else encountered a simular issue.
Thanks in advance
Anthony
Thanks in advance
Anthony
