CJD
Again, I'm at a loss on the front suspension. I had 2 decent vertical links chosen out of a stack of 8. But then the new trunnions arrived. When the trunnion is screwed onto the bottom of the vertical link, there is a bit of play. I had one with no play...but later measured and discovered the vertical link bolt is bent, so it was "wedging" itself into the trunnion...it got trashed. Of the remaining vertical links, I measure betwen .005" of play on one (which I am happy with), and .011 to .013" on all the others.
I can find no references anywhere in the book for trunnion play tolerances. I did find the limits for the through bolt to suspension arm, which is totally different.
So, am I over thinking this, or is .013" play about right?
