G
So I've made up my mind that MPFI and a supercharger is the way to go. The more I read, the better it looks.
With that in mind, I found the attached for sale and purchased it. It's a full PI setup from a 74 supposedly working when removed, the other bits - distributor drive, PI camshaft et al in the other pics I didn't attach. I'm now waiting impatiently for it to arrive.
My thought was to have the throttle bodies converted to use bosch injectors, a common rail attached and the plenum permanently attached to the throttle bodies with fabbed pieces that mirror the flexible connections.
I can then either use the throttles that are on there, or mount a throttle body on the end of the plenum and feed the output from the supercharger through that. A bit of electronics, some spit and a lot of duct tape and hopefully I'll have mpfi. (Seriously I do have some idea of the other pieces I'll need).
My problem now is that I'm having second thoughts. I can probably get an intake manifold fabbed up for about the same as I paid for this setup with the mods and I'm thinking that it's not a nice thing to do to modify this stuff.
So my question I guess is - do you as a group think this is
1) Rare (rather than uncommon)
2) Desirable enough that I should sell it to someone who wants to do a 'real' PI conversion and use the cash to get a custom manifold fabricated?
I have no strong opinions either way, but I'd hate to destroy something irreplaceable.
I quite like way the plenum looks on Lee Jannsens site, but then he isn't using the stock throttle bodies. I'm sure I could get something I'd like just as much made up though.
