Ok so about a month ago I notice a miss in my spitfire when under a load. I go check out everything and decide it must either be a burnt valve or a blown gasket. I pull the head and find out it was the gasket, it blew between number two and number three. I decide I might as well do a valve job while I have it off, so I do a nice valve job new stainless exhaust valves, hardened seats, new magneseium guides, new springs, the works. Then I take it to a machine shop and have it resurfaced. Well then I get caught up with school final papers and studying for final exams. So for three weeks it sits, while I do school work. Then last Sunday I figure I am studied up enough to spend some time with the spitfire. So I pull all my covers to address some oil leaks, esp. the front main seal which was leaking. So I pull my crank pulley and strip the block down bare. I then clean up the block and put the head back on it paint them, and put my mainifolds back on. Next day I take my covers over to my parts store and bead blast all the covers, local parts stores are the best. The when I get home I paint all the covers and tap my new front main into my timing cover. Now its back to studying for finals. So today I go out expecting to put everything back together and get it running, so I do all that no problems till I am putting the very last thing on. It would seem that the privious owner had had a leak at the thermostat housing and had tightend down the bolts, becuase when I put my new bolts in it it stripped out the threads in the water pump housing, so I cuss alot and stomp around some thinking about how I am going to get it running today. Well I switch to a coarse thread bolt and manage to catch enough to tighten it down some, I am at this point very concerned so I cross my fingers and hope for the best. Well I start it up and it runs great, that is if you don't mind the copious amount of water pumping out between the water pump and thermostat housings. So tomarrow I will have to drill out the thermostat housing to 3/8, the water pump housing to 11/32 and retap it to 3/8 then bolt it all back into place. Anyway I am irritated now because its always the little stuff that gets you and here are some pics of the motor as I worked on it and now that it is finished, almost.
Notice my cool blue and white colour scheme, I decided that triumph colurs would be cool, esp since thats what the car will be painted when its all said and done. And yes it is dark ford blue its the closest I could find.
Cheers,
Walter
P.S. Ok so I apparently can't run my computer, can anyone tell me how to upload my pictures, I know I can do cause I've done it before.
[ 05-09-2004: Message edited by: waltesefalcon ]
[ 05-09-2004: Message edited by: waltesefalcon ]</p>
Cheers,
Walter
Hi Guest!
