I have a problem.. Bsides living in the UK.. I have a healey BN4 with a 3000 engine running twin SU carbs. Lucas Ignition.
I ran out of petrol{gas} silly fool but the guage had become faulty without me knowing. I was I arrange a tow back home and put the car in the Garage.
Three days later I put some petrol in and tried to start her up... NO GO.. turning over but not firing at all. I cleaned the float chambers out as these were full of crud.
The car then fired but would not run except with full choke. even then it was very rough. Its was spitting back through the carbs with plumes of white smoke and the occassional flash {more like back firing through the carbs.}
I took the carbs off and blew the lines through with compressed air. and tried again.. still the same. will fire but wont run except on choke and then only for a few seconds. still plumes of smoke from the carbs and the spitting back.
I thought I may have go an ignition fault.. so I checked it over. all seems well I replaced the condenser. with no difference. I changed the contact set. No change. I changed the coil. no change. I changed the plugs no change. I checked the timing. no change... the only thing I have yet to try is the rotor arm.. thats next but if you have any idea as to what could be the problem I would like to hear from you. The car was running perfectly prior to running out of juice.
cheers
cheers
