tahoe healey
I need to somehow move the window crank in-board 1/2 inch. It is pulling on the interior door panel. Is there an adjustment?
TH
TH
Hi Guest!
tahoe healey said:Nothing changed. The previous wood was bent in too. The new wood is 1/8 inch the old one was thicker.
The problem is the paneling is bowed inward separating it form the lower panel.
anthony7777 said:ausmhly, hes not happy with problem of the old 1/8 wood being "bowed in", and now with new 1/8" wood hes still has the same problem.
I think it would be great to see some photos because I'm having a hard time visualizing the problem. I've owned my BJ8 since about '73 and have taken the doors and interior panels off many times but never had a window crank fit problem.AUSMHLY said:anthony7777 said:ausmhly, hes not happy with problem of the old 1/8 wood being "bowed in", and now with new 1/8" wood hes still has the same problem.
Something just isn't right here.
The "old" was thicker than 1/8". The new is thiner at 1/8"
I would assume at one time the "old" panel was on the door.
Sounds like it's the panel that needs attention, not the shaft.
What is the measurement from the metal door skin where the shaft come through, to the back of the door handle crank when the pin is in the handle, no panel on the car.
Even if the door skin got bent out, the crank mechanism gets screwed flush up to it. So the amount of the shaft coming out, would not change.
This is an interesting problem solver you have here Rich.
As per Keoke's point, on my car the crank protrudes from the face of the fixing panel that it is fixed to by 2.1/8". Also if I put a straight edge across the door outside edges, the crank only protrudes 1/8" indicating the interior panel must have to bow in towards the crank slightly.
