wohooo it runs
Stewart
A 1 weekend job turned into 3 weeks but it looks like it was worth the hassle. Car started right up once I had the timing right. Cam run in was nice and smooth with no funky noises or leaks and the car stabilized a hair over the N after 10 min and stayed there for the rest of the run. Un DPOing the clutch was well worth it as now it fully disengages and works smooth even with a little bit of air in the line.
Later this evening It will be a quick oil change re bleed the clutch, move the dizzy gear over a tooth then a full tune and it should be good to go and after driving my truck for the last 3 weeks I'm going to enjoy not having to fill up all the time.
YAY fer Stewart!!! :thumbsup:
Just got back from the full test run. Runs fantastic. Start with a bump of the starter idles smooth even with the cam and pulls well. Best part is I can now shift with my pinky if I so desire as its so effortless. And the very best part no more wierd clunks when its shut off thanks to the now non jello like trans mounts.
Time for beer
