vping
So the B is running but I have some wiring issues. I checked out all of the electrics when I got the car and with the exception of the Reverse light being on all the time, everthing worked. I assume a stuck switch. Hazzards, signals, heater...even the interior and trunk lights - all worked.
The motor and trans were pulled, old trans removed and an OD joined up with original motor. Back in the car and here is where I am at.
All lights are on but Signals don't work & reverse lights do not come on. The strange thing is that when you put it in any gear, 'cept reverse, the RH front & rear signal come on. There also is no power from the yellow wire coming from the Washer stalk so it is not sending power to the OD.
