Wiring connections for starter solenoid
als
Can someone direct me to a detailed wiring diagram for the starter solenoid on my 76 Midget. The diagram I have is for a slightly different arrangement. I didn't take quite enough care in documenting the wire positions when I took the car apart a few months ago. Any help would be appreciated.
Thanks
Al /ubbthreads/images/graemlins/canpatriot.GIF
If your wiring hasn't been PO'd You should have the battery cable running to one of the large posts on the solenoid along with three brown wires. The three brown wires are: one coming from the gen/alt, one going to the fuse block, and one going to the light switch. On the small post between the two large posts a White/red wire which goes to the ignition switch. Also the large cable going to the starter from the other large post on the solenoid.
