Slider748
Hi Guest!
Did the car have wire wheels before? If not, how do Moss's adapters differ from anyone else's so that they don't require spacers or shortening the lugs? Just curious....Slider748 said:For those who are considering wire wheels for their TR6, here is a picture of mine with Diamond Back Series I 185/80- R15 redline tires mounted on Dayton 6” rims. I used Moss adapters with no spacers. The suspension is stock.
Worth noting, perhaps, that the factory-approved procedure was to cut off the longer studs, using a hacksaw ! With care, a cutoff blade in a grinder will work too.Slider748 said:The car did not have wire wheels before. I pounded out the old lugs and replaced them with new shorter ones from Moss.
Right, Randall, and that's why I posed the question! It is something that was [re-]emphasized in a fair number of Triumph Service Bulletins over the years, that the studs MUST BE SHORTENED when fitting the wire wheel adapter hubs! (I'd have to look up the exact amount to be removed, but ISTR it was somewhere around 5/16".)TR3driver said:Worth noting, perhaps, that the factory-approved procedure was to cut off the longer studs, using a hacksaw ! With care, a cutoff blade in a grinder will work too.Slider748 said:The car did not have wire wheels before. I pounded out the old lugs and replaced them with new shorter ones from Moss.
