I have a '75 MGB that has been converted to wire wheeks by a previous owner. Recently, I started to hear a clunk from the front end when the brakes were applied. This only occurred whilst the car was moving, never stationary. There was some slight noise from the pedal assembly, but no real slackness. Suspecting something loose in the brake area -- caliper or pads, I jacked up and removed each front wheel in turn and checked for anything loose. Finding nothing, I greased the splines and replaced each wheel. Result: clunk had gone.
Here's my question:
When I removed the wheels, it seemed to me that I needed a lot of effort to get the spinners off. So they were definitely securely attached. Is it possible for the wheels to seem to be secure, but actually loose enough to cause a noise when the brakes are applied?
Thanks in advance for your advice.
Here's my question:
