YOu can switch a wire wheel MGB to bolt, using the same rear end housing, on the rear you need longer studs, they are some that will just knock on, and a bout .300" wheel spacer, several guys including myself have done this and documented over at the MGBex site. But here the catch, you can't go the othert way, meaning putting wire wheels on bolt rear housing, if you going that way, it a entrire rear end housing swap.
