Wiper set up help needed
Don Jarr
Member
Hi
I’m after a bit of information, regarding what classic cars use the same windscreen wheel boxes and cable that a mini does. The cable pulls and pushes to operate the wipers.
I’m actually trying to find out if any other cars use a longer length of the spiral cable, as I have built a custom car, and the wipers go in and out, opposes to side to side, and I could really do with a longer length. The Mini length works, but it really would be better if it was about 6 inches longer.
So if any one knows any other car that uses this type of wiper set up, I would be really grateful if you could let me know, so I can find out what length they use.
Thanks
Don
The early Lotus Elan's use the cable setup for sure, but I don't know which car they borrowed it from... And chances are the Elan cable is not longer than the Mini's.. since the cars are about the same width..
