69sprite
As posted earlier, my '69 had a boo-boo and I am in the process of having to remove the wipers/wiper posts/windscreen squirters/etc so that the person repairing the bulkhead valance panel can begin his work.
What should have been a simple task has turned into a pain. After removing the wipers, I started work on the nuts to remove the bezels from the three wiper posts. One (driver side) was relatively easy, but the other two (center and passenger side) are being a pain in the backside. They appear to have welded themselves into place over the ages. Repeated attempts at soaking with PB/WD/etc and then attempted removal had results in two seeming non-budging nuts that are close to not being nuts anymore.
I am at the point to where I am seriously considering getting my Dremel took and being cutting them off, but wanted to check with any resident wizards out there that might have any suggestions before I do so. I am working hard to keep from messing up the wheel box/cable/mounts or motor as they are the more expensive parts. I don't mind replacing the nuts/bezels as long at the ones Moss carries are of decent quality.
So, any ideas?
Thanks
Larry Swofford
So, any ideas?
Thanks
Larry Swofford
Hi Guest!
