Wiper Motor Removal
78Z
Ok I'm probably missing some obvious but I want to remove the wipers and motor from the car. I can get the nut to loosen but then I hit the wiper. Is there a trick to this? Thanks.
The wiper pries off. Use two screwdrivers for leverage if needed.
But you need to tighten that nut under the wiper first.
Thanks all. I got it out. I would have thought I was doing it wrong and breaking them without the advice.
