Webb
Alright: I completely unassemblemed the rack and motor mechanism, and cleaned and greased everything thoroughly. Rack is very smooth, no hangups there. The worm and final gears are in good shape, with very little wear on them. All the bushings and washers are present.
I got it all greased up and put back together, but before attaching the rack or connecting rod I put it to power to see what would happen. It started off very slowly as before, went through a cycle, and started to speed up, but it started to make a low pitched squeal once it got up to speed. Problem is definitly in the motor somewhere. The "brushes" looked good...they are actually some sort of block. Connections are good to the brushes, and to the plug on the outside of the motor.
I noticed the armature was extremely hard to turn by hand when I had it out of the con rod casing...definitly not spinning freely. I assume this is why it's not working right. What would be causing this?
*note: I used lithium grease as that's what I had readily at my disposal. I hope this is a suitable grease. Even if it isn't though, I know for sure it's not why this thing is screwed up.
